What Type Of Plug Is This? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2010, 10:50 AM   #1
What type of plug is this?
Hi everyone,
Here's a link to the picture :
http://sites.google.com/site/mathewar/home/homestuff
I've got, what I believe is an air conditioner plug next to the window in the bedroom of our apartment. I'm trying to figure out what type of plug I need to make sure the window AC that we buy needs to have. Attached is a picture of what it looks like.
I'm reasonably sure its 110V (from looking at the renovation papers, the apartment was renovated before we moved in), but I can't use an electrical tester to verify it (the holes appear to be blocked off).
A few questions :
- Are the holes blocked off for safety? How do you open it up?
- What type of socket/plug is this?
- What do I need to look for in an AC that I buy to make sure it will work?
Thanks all for your help!
-Arun
agmathew is offline   Reply With Quote
Old 07-24-2010, 11:02 AM   #2
Electrician
Proby's Avatar
All you need to do is make sure the AC is 120 Volts.
What you have is a 20 Amp 120 Volt Tamper Proof receptacle. You just slide a plug into it and the "blocked holes" will open up for you.
Proby is offline   Reply With Quote
The Following User Says Thank You to Proby For This Useful Post:
agmathew (07-24-2010)
Old 07-24-2010, 12:07 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Just to add to what Proby said so that you don't 'overthink' this ...
The T-Slot you see on the face of the receptacle is so that any 120 volt plug 15 or 20 amp will fit the receptacle.
The branch circuit is most likely a dedicated (individual) circuit to that single receptacle...ie..no other receptacles on that circuit.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 07-24-2010, 01:27 PM   #4
Thanks all
Thanks everyone for your help - now I just need to find an airconditioner in stock in stores somewhere around here!
Circuit breaker Type Q vs QP orange Electrical 6 12-15-2010 04:35 PM
2002 and 2003 side mirror plug configuation sv9779 Automotive Repairs 2 12-23-2009 09:19 PM
removed old romex (added new wire) and added a plug doesn't work now? Limit54 Electrical 9 11-08-2009 10:03 PM
Leaking main drain clean out plug bucksone Plumbing 1 01-10-2009 08:42 AM
New plug for toaster oven? mike720 Electrical 3 11-23-2008 08:44 PM
