What Type Of Outlet Is This?? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-27-2011, 12:11 PM   #1
What type of outlet is this??
I'm renting, and I need to upgrade my AC unit. I go to remove the unit, and I see this type of outlet. I've never seen anything like this before... does anyone know what this is?? Thanks for the help!
jimgard is offline   Reply With Quote
Old 06-27-2011, 12:13 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 266
That is a 6-15R, meaning 15 amp, 240 volt.
It should be attached to a 2 pole 15 amp breaker.
jbfan is online now   Reply With Quote
Old 06-27-2011, 12:21 PM   #3
I see, thank you. From what I can gather, this is a common receptacle for wall A/C units? Should I expect to find a new unit at a local appliance store that will fit this receptacle? What I'm seeing online is that most units just have standard parallel plugs...
Old 06-27-2011, 12:59 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
If the units you are looking at have parallel blades they are 120 volt units not 240 volt. Usually 120 volt units are in the smaller BTU sizes and the 240 volt units are higher capacity.
What is the BTU of the existing? You probably do not want to go smaller. If you go with a 120 volt unit that receptacle will have to be replacedand the circuit rewired.
Coastal South Carolina
Old 06-27-2011, 01:05 PM   #5
The current unit may or may not be the first air conditioner ever made; it's very old. So I'm not actually sure what the BTUs are, but I'm going to guess my landlord would want to go with a bigger unit and not want to worry about rewiring the receptacle. Thanks for all your help!
Old 06-27-2011, 11:44 PM   #6
" Euro " electrician
frenchelectrican's Avatar
The typical size of the A/C unit is useally larger than 12,000 BTU size useally in 12 to 15,000 BTU size for that receptale the larger one will take diffrent receptale complety and it will be much larger on size wise.
Merci,
Marc
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 09:36 AM
Adding Ceiling Light From Switched Outlet vboz5 General DIY Discussions 2 03-04-2009 01:53 PM
Help Help richie02 Electrical 7 06-17-2008 09:42 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
