What Type Light Bulb With Dimmer Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2007, 01:47 PM   #1
Rewards Points: 123
What type light bulb with dimmer switch?
What type of light bulb should I use with a dimmer switch?
jerome8283 is offline   Reply With Quote
Old 11-10-2007, 02:07 PM   #2
Union Electrician
goose134's Avatar
The question you should be asking is what type of bulb should I use in my fixture, and can it be dimmed?
Let us know what type of fixtures you have and that will help. If they are low voltage fixtures, let us know what kind of transformers they are equipped with. The fixture will be marked.
goose134 is offline   Reply With Quote
Old 11-10-2007, 02:35 PM   #3
Rewards Points: 123
It calls for 2 - E 100 Watt bulbs.
http://www.csnlighting.com/asp/show_...28#ManuDetails
Old 11-10-2007, 03:38 PM   #4
Electrician philosopher
E-100 are compact flourescents, aren't they???
Andy in ATL is offline   Reply With Quote
Old 11-11-2007, 12:25 AM   #5
Union Electrician
goose134's Avatar
I can't be 100 % sure, but I think that when they say E-100 they are referring to Edison base 100watt lamps. It's as simple as that. Get two 100 watt frosted glass lamps, and a standard incandescent dimmer and you should be set.
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Dimmer Switch Problems? dmtm21 Electrical 2 08-07-2007 01:18 AM
Wiring a light with switch....please help!! lindo1951 Electrical 19 10-16-2006 02:32 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 03:52 PM
OK to user a dimmer with ceiling light? FreeCashBack.co.uk Electrical 2 06-19-2005 09:16 PM
