What Type Of Electric Cord Is This? Need Converter Cable. - Electrical - DIY Chatroom Home Improvement Forum
Old 08-18-2012, 04:10 PM   #1
What type of electric cord is this? Need converter cable.
I need a converter cable, but I cannot find the one I need. The cord I have (see attached image) obviously won't fit into the standard wall outlet.
WHAT TYPE OF CABLE DO I HAVE AND WHERE CAN I FIND A CONVERTER CORD FOR IT??
The cord is for a pump on my well system; the water in my family's home is hard and starting to smell.. please help!
Thanks so much!!!
confusedaboutit is offline   Reply With Quote
Old 08-18-2012, 04:21 PM   #2
Rewards Points: 14,026
That looks like a 220 volt plug not a 110.
Not sure what pluging in a well is going to have to do with hard water.
Do you have a water softner?
If the pump to the wells not pluged in how do you even have any water?
http://www.stayonline.com/reference-...ght-blade.aspx
Old 08-18-2012, 04:26 PM   #3
the Musigician
DangerMouse's Avatar
What does that plug IN to?
DM
Old 08-18-2012, 05:41 PM   #4
Looks like it's meant for a 20A 240V receptacle...where was it plugged in before?? I'm slightly confused.
LooseSCruz is offline   Reply With Quote
Old 08-18-2012, 05:48 PM   #5
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
DM
250 volt / 15 amp. The plug is a NEMA 2-15P. It plugs into a NEMA 2-15R (like the receptacle Marc provided).
What type of electric cord is this? Need converter cable.-image-2505590978.jpg
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
jeepdawg (08-18-2012)
Old 08-18-2012, 09:24 PM   #6
" Euro " electrician
frenchelectrican's Avatar
To the OP .,
The receptale you should have in your house look like this
That is 15 amp 240 volt circuit.( this is 6-15 R )
If you do not have this please stop right there and posted back here quick we can tell you the correct way to do this.
Merci,
Marc
Old 08-19-2012, 06:56 AM   #7
the Musigician
Could you perhaps tell us what the information plate on the pump says?
DM
Old 08-19-2012, 12:13 PM   #8
electures's Avatar
Thanks so much!!!
A "converter cord" won't work. This is a 15A/240V plug. It needs a 15A/240V circuit.
Tags
cable , cord , electric , power
Roofers Damaged Electric Cable? RalphPeters Electrical 6 08-15-2010 12:47 PM
Ele hot water tank and welder sharing circuit wazeaz Electrical 68 03-19-2008 07:17 PM
Transformer Help chcustom Electrical 28 12-10-2007 10:40 PM
Which type of Armored cable. helpless handyman Electrical 4 12-01-2007 09:04 PM
What type of electric do I have in mu house? SleepnZJ Electrical 44 09-23-2007 07:46 AM
