-   -   What is this type of connection called? (http://www.diychatroom.com/f18/what-type-connection-called-168239/)
onox 01-04-2013 02:50 PM
Sorry for the upside down image. Anyway, I accidentally soldered one of these so it wasn't flexible anymore, and we need new ones anyway. But I have no idea what it's called. I asked the engineer that works with me and he's not sure either. It's kind of a silly question, but I need new ones. Anyone know what this connection is? Thanks in advance
http://img267.imageshack.us/img267/2963/photo3ui.jpg
ddawg16 01-04-2013 03:01 PM
Do a search on Molex. That is a common connector...but the actual one will depend on the connector body being used.
onox 01-04-2013 03:39 PM
Thanks ddawg. I found a couple on the Molex site, but they are huge! I am trying to hook up an LED (just one LED) with a resistor to a standard DC power output. Not quite sure what you mean by "connector body", but I assume you mean what this connector is actually supposed to feed into? If that's what you mean, we just run them to a little rubber 2-hole body (about 0.6cm by 0.4cm, 1.5cm height) which we plug 5mm LEDs into. I'll keep looking though, thank you much :)
joed 01-04-2013 06:39 PM
They will be specific to the manufacturer. You need to determine who makes the plug. Post a picture of the entire connector and maybe someone can identify it.
onox 01-04-2013 09:30 PM
I will post a picture Monday, the piece is at work.
dmxtothemax 01-04-2013 09:38 PM
Broken !
It's part of a plug / header assembly !
Dont know for sure if it's available as a spare part,
As its usually part of an assembly.
gregzoll 01-04-2013 09:52 PM
They make them smaller.
md2lgyk 01-05-2013 07:02 AM
Try the McMaster-Carr website. They sell more miscellaneous doodads than any place I've ever seen.
onox 01-08-2013 10:27 AM
2 Attachment(s)
Okay, so here are some pictures of the full connector. (Please don't lynch me! I know it's ugly, but it's homemade, and I'm not an electrician :P)
Basically the idea is to connect a standard 5mm LED to a power supply, and have it fit snugly inside our instrument. Every standard LED power supply I've seen is to power strips of LEDs, not just one, and I'm not sure how we'd get a strip to work properly for our purposes. The connector I showed earlier goes into the red rubber piece, allowing for a snug connection for the LED. The electrical tape near the end of the thick black power cord is where the resistor sits.
Although I would like to repair this to get it working, I would much rather just have a way to power one single LED that's actually meant to do just that, and we don't want to drop several hundred dollars on an ocean optics power supply which is why we had this rigged solution. If anyone knows of any other methods of achieving this I am all ears.
electures 01-08-2013 01:29 PM
Try amphenol or molex. I did find this under molex;
http://narkedat90.com/shop/UserFiles...background.jpg
