What Is The "trick" To Installing Those Plastic Carlon Boxes To Studs For New Work - Electrical - DIY Chatroom Home Improvement Forum
Old 01-13-2013, 07:37 PM   #1
Demolition Mode
Rewards Points: 129
Send a message via Yahoo to HandyDave
What is the "trick" to installing those plastic Carlon boxes to studs for new work
I dinked around today for about 1/2 hour trying to straighten out a 2 gang new service box.
Pic here http://www.homedepot.com/h_d1/N-5yc1...1#.UPNghR34Ljs
What is the trick to getting these things flush with drywall. Why on earth do they have a 3/8 "leg on them when most of us DIYers use 1/2 drywall?
I measure 1/2 inch pound it to the stud and it has goofy twist etc... Anyone know a solution?
HandyDave is offline   Reply With Quote
Old 01-13-2013, 07:45 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Stud twisted?
I use a piece of 1/2 press board or drywall to set the boxes.
jbfan is online now   Reply With Quote
Old 01-13-2013, 07:45 PM   #3
Rewards Points: 93
Use metal boxes
George6488 is offline   Reply With Quote
Old 01-13-2013, 07:47 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Originally Posted by George6488 View Post
Use metal boxes
On wood studs with NM cable?? YUK!
The Following User Says Thank You to Speedy Petey For This Useful Post:
brric (01-14-2013)
Old 01-13-2013, 07:49 PM   #5
Those thin blue boxes suck! You have to nail them in absolutely perfect or they will twist like you are experiencing.
If I have to get the blue ones I get the heavier ones that are MUCH sturdier. They will not twist.
Old 01-13-2013, 09:14 PM   #6
Rewards Points: 1,500
Hold it with your thumb in the box while hammering. Studs with sharp edges work better.
mikegp is offline   Reply With Quote
Old 01-13-2013, 09:23 PM   #7
Rewards Points: 14,306
There suppost to be slightyl recessed, better that then sticking out to far and the cover will not sit flush with the wall.
Old 01-13-2013, 09:24 PM   #8
Ok withthis model of boxes I only have problems when doing 3 or 4 gang but it is better to work with the sturdier type and the onlyreason I can think of for you to have problems with a two gang box is that the stud is crooked
RAUL HIDALGO is offline   Reply With Quote
Old 01-13-2013, 09:37 PM   #9
Actually they are supposed to be flush, but are allowed to be slightly recessed. How much depends on the wall material.
Old 01-14-2013, 06:27 AM   #10
Demolition Mode
Rewards Points: 129
Thanks for all the tips and advice. I think I am gonna try to make a lil jig out of plywood. There was some great information in this post..Thanks again.
Old 01-14-2013, 07:12 AM   #11
Rewards Points: 1,548
One reason why the box ends up being crooked is that the nail doesn't go into the wood exactly where you started it.It is the wood grain tthat "steers" the nail slightly to one side or the other.
For boxes of 3 or more gangs, the box itself is too floppy to stay in place. You need a strip of wood going horizontally between the studs to hold the box in place.
The Following User Says Thank You to AllanJ For This Useful Post:
Speedy Petey (01-14-2013)
Old 01-14-2013, 07:16 AM   #12
Demolition Mode
Rewards Points: 129
Thanks Allen J i think you hit the nail right on the head here.... (no pun intended) I am only using single and occasionally a 2 gang box.
Old 01-14-2013, 09:27 AM   #13
Rewards Points: 243
I've used a C-clamp to hold the box against the stud while driving in the nails before.
chemman is offline   Reply With Quote
Old 01-14-2013, 09:56 AM   #14
Thinking about how I nail those in...
I hold the box to the stud with my left hand (thumb and hand to make "C clamp"), tap in the top nail just a little - maybe 1/2 inch.
Then tap in the bottom nail 1/2 inch.
That gets it straight.
Then pound the top nail in all the way and then the bottom nail all the way.
If a nail is not in straight after pounding it all the way in, I pound it forward or backward with the hammer (bending the nail).
If a nail hits a knot and kinks, I cuss, rip the whole thing out, and use a new box.
Billy_Bob is offline   Reply With Quote
Old 01-14-2013, 09:58 AM   #15
Licensed electrician
Rewards Points: 1,876
You can also add a piece of false stud on the outside of the box away from the true stud. There is a flange you can screw through to secure it.
Blue plastic receptical/switch boxes used as junction boxes? alexz Electrical 7 04-09-2013 08:40 PM
Old Work boxes - wiring management in walls Jaxx Electrical 8 03-25-2012 03:05 PM
Installing new work boxes- distance from stud face toobhed Electrical 9 08-06-2011 08:54 AM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
Gangable old work boxes kornbln Electrical 2 05-27-2008 05:50 AM
