Old 03-28-2011, 11:12 AM   #1
Question
What style breaker for unfinished/basement area
I would like to know what style breaker to use that a chest freezer would be plugged into. The freezer is placed in the unfinished side of a basement (ie furnace room area). I have been using AFCI breakers for the finished areas, but not clear on if the freezer needs AFCI,GFCI of standard.
Also, am I understanding the code correctly, that outlets located in the unfinished area, need to be GFCI protected?
xracer is offline   Reply With Quote
Old 03-28-2011, 11:51 AM   #2
J. V.'s Avatar
Yes. If it's unfinished, it needs GFCI protection. But a breaker is expensive. Just use a GFCI receptacle.
Old 03-28-2011, 12:18 PM   #3
Wouldn't a GFCI be tripped each time the freezer's compressors start up?
Old 03-28-2011, 12:21 PM   #4
Electrical Contractor
Not if the compressor is in good working order.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Checking a Breaker Klawman Electrical 11 02-18-2010 08:48 PM
Circuit Breaker, working in reverse dcwestcott Electrical 4 04-06-2009 04:03 PM
Tandem Breaker and Circuit(s) whowadat Electrical 1 01-09-2009 05:13 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
