What Size Wire To Use - Electrical - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 05:26 PM   #1
what size wire to use
we have an antique electrical panel in house we are upgrading to a 200amp panel outside. we have to have a 125amp junction box in the house to keep from having to rewire whole house. what size wire to we need to run from the juction box to the outside service panel 30' away
moliver1966 is offline   Reply With Quote
Old 07-29-2012, 05:36 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
What is a 125A junction box?
Old 07-29-2012, 06:42 PM   #3
Master Electrician
i think what they're doing is putting in a new service and feeding the old one off the new one. Still doesn't change the fact that it's a strange question. Why not just feed the old panel direct from the new panel.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-29-2012, 07:15 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
I see I am not the only one who is completely confused by this strange statement.
Old 07-30-2012, 01:15 AM   #5
" Euro " electrician
frenchelectrican's Avatar
I am half way lost no matter which way I try to translated in here ( both English or French )
Now let start here .,,
Outside service panel is that your main panel or main breaker / fuse for the whole place you have there ?
Now next step is 125 amp junction box are you refering to the splice box to tie in the cables or what ??
I am thinking you may still have old style 100 amp breaker/ fuse box if so., my hunch that you still want to make a splice point to the new outdoor load centre ?
If so that will open up new cans of worm if you go that route due you will denfely need keep the ground and netural seperated which it mean a 4 conductor cable.
The best thing you can do is post the photo of it so we can figure it out.
Merci,
Marc
Old 07-30-2012, 01:46 AM   #6
<snip>
Merci,
Marc
It's all Greek to me too!
Evstarr is offline   Reply With Quote
The Following User Says Thank You to Evstarr For This Useful Post:
frenchelectrican (07-30-2012)
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 09:38 AM
wire size for 160' feeder to subpanel steveski Electrical 3 05-21-2011 09:41 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
