What Size Wire To Use - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 09:42 AM   #46
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I don't understand what you are saying...if there is 0 resistance, the voltage drop would be 0.
Old 05-28-2012, 03:24 PM   #47
Try this also
http://www.scribd.com/doc/77443292/1...HVAC-NAMEPLATE
Zero resistance in the Romex cabling.
The panel, looking back into the PoCo, has a non-zero resistance which is the Thevenin equivalent impedance.
For my panel it's 0.022 ohm which gives me a 240v/.022 ohm = 10,800A short circuit current.
You can measure this yourself with a wall oven/stove and a 4-1/2 digit DMM.
From another thread, houses down the block may only have 240/0.08 = 3kA short circuit current.
If you pull 400A from your car battery and it's terminal voltage drops to 4v, it's equivalent impedance is about (12.8-4)v/400A equals also 22 milliohms.
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 09:38 AM
wire size for 160' feeder to subpanel steveski Electrical 3 05-21-2011 09:41 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
