What Size Wire For Electrical Dryer - Electrical - DIY Chatroom Home Improvement Forum
Old 07-19-2006, 12:58 PM   #1
what size wire for electrical dryer
I need to relocate my dryer from first floor to basement... now I need to setup new outlet for it... Could you tell me what size wire I should use, I believe it is being connected to 30Amp 240V breaker... would it be #8 or #10...
question for washer, what type of breaker I should use? 20 Amp ?
KUIPORNG is offline   Reply With Quote
Old 07-19-2006, 02:27 PM   #2
Washer-Dryer
A dryer requires a 30amp circuit with 10-3 (red-black-white & ground) wire.
A washer requires a dedicated 20amp circuit with 12-2 wire.
manhattan42 is offline   Reply With Quote
Old 07-21-2006, 04:35 PM   #3
Verify first what size breaker the dryer is on, if it is a 30 then use #10, if it's a 40 or 50 then use #8
Sparky Joe is offline   Reply With Quote
Old 07-22-2006, 04:59 AM   #4
Most dryer plugs and outlets are 30 amp. Be sure that if the dryer outlet is 30 amp that the wire size is at min number 10 and that the max breaker size is 30 amps. Do not put a 30amp outlet on a 50 amp breaker.
jwhite is offline   Reply With Quote
Wire size for distance Question fburke Electrical 4 07-28-2007 10:29 AM
Wire Size Help-400ft line to pond for fountain brownie47854 Electrical 14 04-22-2007 01:50 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
Wire size for Central Air mwtuck HVAC 2 12-01-2006 06:06 PM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 08:43 PM
