what size wire for electrical dryer
I need to relocate my dryer from first floor to basement... now I need to setup new outlet for it... Could you tell me what size wire I should use, I believe it is being connected to 30Amp 240V breaker... would it be #8 or #10...
question for washer, what type of breaker I should use? 20 Amp ? Thanks |
Washer-Dryer
A dryer requires a 30amp circuit with 10-3 (red-black-white & ground) wire.
A washer requires a dedicated 20amp circuit with 12-2 wire. |
Verify first what size breaker the dryer is on, if it is a 30 then use #10, if it's a 40 or 50 then use #8
| All times are GMT -4. The time now is 10:07 PM. |
