Old 10-09-2008, 03:25 PM   #1
What size wire do I have?
From my house to my detached garage I have aluminum wire run. On the wire it is printed 2x2 + 4 AWG. There are 3 wires coming into my subpanel, 2 hots and one nuetral. Does this mean that the hot wires are number 2 guage and the neutral is number 4? Most of the writing on the wire is rubbed off, but it also says XLPE and phase conductor 2. I could barely read the manufacturere name which is Centelsa. I went to their website but it was not much help.
Can anyone provide their knowledge here? Thanks.
737Pilot is offline   Reply With Quote
Old 10-09-2008, 05:03 PM   #2
Electrician
This is not a cable correct? Sounds like they ran URD, so it would be TWO # 2AWG and a reduced neutal wire at #4 AWG. Pretty common.
chris75 is offline   Reply With Quote
Old 10-09-2008, 05:26 PM   #3
DIY'r
ScottR's Avatar
Originally Posted by chris75
Pretty common.
No pun intended.
ScottR is offline   Reply With Quote
Old 10-09-2008, 06:59 PM   #4
After looking up URD wire, I believe you are right. Thank you. Now, this 100A subpanel is about 120 feet from the main panel. Is this wire size OK? THanks again.
Old 10-09-2008, 10:47 PM   #5
Electrician
Technically speaking, it should be supplied by a 90 amp breaker to meet code.
Aluminum wire size/ guage / amps? walt1122 Electrical 17 07-30-2008 11:44 AM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 06:00 PM
Wire size for distance Question fburke Electrical 4 07-28-2007 10:29 AM
Wire size for Central Air mwtuck HVAC 2 12-01-2006 06:06 PM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 08:43 PM
