What Size Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-19-2010, 11:42 PM   #1
Question
What size wire?
Need power to shed/Man Cave. Shed is 23ft from pole and I figure by time I get in and run the wire to other side I'm lookin at 65feet of wire at most.
Gonna run at the most at 1 time would be a 120v welder, radio, and light. I guess welder would be main concern. It calls for a 20amp 60hz breaker. I would be runnin air compressor and other power tools, but only one at a time.
I could just put 20amp breaker in main box, but what wire size/kind of wire should I run? I was thinkin 10-2. Open for suggestions.
oops is offline   Reply With Quote
Old 06-20-2010, 03:01 AM   #2
" Euro " electrician
frenchelectrican's Avatar
How much room you have left in your load centre ??
I really strongly recommend that you go with subpanel route you will reduce the chance get anything trip from overload especially if you only have one circuit going to the shed and the code is pretty strict with the numbers of circuits it can run to detached buildings they only allowed one { it can be either single circuit or one MWBC (multiwire branch circuit ) only }
Of course all the 120 volt circuit it must have RCD { GFCI } especially if you are on 2008 NEC code cycle there is no extempts on them unless your local code may say something different.
Merci,Marc
Old 06-20-2010, 09:44 AM   #3
Smile
The main panel outside has a bout 5 slots left in it. Right now theres a 20amp breaker on it running a plug on pole and outside street light mounted on top of it.
I'll run a sub panel thats kool. What size breaker should I put on pole and what size wire should I run to shed?
Any other thoughts or suggestions are greatly apperciated.
Oh yea, and I'm dead in the water here. I can do anything with wood, but I just don't get the eletrical stuff. So feel free to go into detail.
As long as I got three 120v plugs I'm happy. One for outside and two inside. Then I'll feel like a HERO and not a oops.
Old 06-20-2010, 10:49 AM   #4
Lowest I would go is 60a sub panel
Buy a 100a panel w/main breaker & feed it with a 60a 240v breaker
2 #6 hot wires
1 #6 white neutral
1 #10 green ground allowed
All THWN in 1" conduit
2 grounding rods at the detached shed
Do a search on sub-panels here & read a few threads
Then if you have specific questions post back here
Old 06-20-2010, 11:15 AM   #5
Smile
Thanx for the comments.
The Following User Says Thank You to oops For This Useful Post:
plummen (06-20-2010)
Old 06-20-2010, 01:22 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
are you coming from a power pole to feed this or is it coming from your house?
plummen is offline   Reply With Quote
Old 06-21-2010, 12:47 AM   #7
This is coming off pole. 35ft min. from pole. 75ftmin. from house.
Old 06-21-2010, 01:53 AM   #8
As far for the pole set up what is the main breaker size you have there and what the breaker size going to the house alone so that way I can or other members here can able figure out how big the max size we can able feed to the shed { I figure 60 amp will be plenty big as long you don't use the 240 volt buzzbox ( AKA stick arc welder ) at full tilt { speed } otherwise 40 or 50 amp will be a doable size as well.
The other thing why I really recomed the MWBC set up due the code only allowed one circuit to detached building so that is the other gotcha if you don't plan it ahead of the time and you will not have to run second or third circuit in there and with Subpanel that will take care the issues.
Yeah the conductor it have to be in 4 conductor format the colours will be Black , Red , White et Green or bare and you can run them in 16mm˛ { 6AWG } and run them in one inch PVC conduit { I know code say 3/4 is the smallest size you can run but I will not bother this size espcally if you have two ells there.}
and the conduit have to be buried at least 24 inches { some area may allowed 18 inches }
Merci,Marc
Tags
breaker , shed , size , welder , wire
Size and type of entrance wire for 200A? Beemer533 Electrical 7 03-15-2010 11:54 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
What size wire do I have? 737Pilot Electrical 4 10-09-2008 10:47 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 06:00 PM
