What Size Wire For 70 Amp At 107 Feet - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-27-2012, 06:12 PM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by kenb1023 View Post
They say since the out building has it's own grounding rods the 4th is not needed.
Ugh... what code cycle are you on, and ground rods do not accomplish what a grounding conductor does...
680.25 (B) requires a grounding conductor.... and you would still need ground rods...
Old 07-27-2012, 06:15 PM   #17
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Really?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 07-27-2012, 06:16 PM   #18
E2 Electrician
Originally Posted by electures View Post
Really?
Just keeps getting better, yes? I can only imagine the other code violations.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Speedy Petey (07-27-2012)
Old 07-27-2012, 06:17 PM   #19
This is New Mexico, I think codes just came about in the past 20 years or so.
kenb1023 is offline   Reply With Quote
Old 07-27-2012, 06:18 PM   #20
electures's Avatar
I wanna see the conductors in free air.
Old 07-27-2012, 06:19 PM   #21
E2 Electrician
I wanna see pictures of everything.
Old 07-27-2012, 06:26 PM   #22
I just want to make this right. I knew what they were doing was wrong but I needed validation on it. Now I have it. The trench is still open, the roof is not on yet so I am at a point the things can be fixed. It is a good thing I only put a third down for the project. I will need the leverage to get it done right.
Thanks,
Old 07-27-2012, 06:27 PM   #23
E2 Electrician
Thanks,
Do you have inspections in your area?
Old 07-27-2012, 06:40 PM   #24
I am in the midle of no place NM. There are more cows than peopel. Getting inspectors out here is like getting DC to balance the budget
Old 07-27-2012, 06:42 PM   #25
E2 Electrician
Gotcha...
Here is a great pdf file on article 680...
http://www.mikeholt.com/files/PDF/Pooldownload.pdf
Old 07-27-2012, 06:52 PM   #26
Gotcha...
Thanks, last I heard New Mexico was still under code 80 something. I wish I could remember when I was having this conversation when we moved out this way 3 years ago. Love the openness but the isolation can wear on you. We came from WI. They are very strict on a lot of things. I remember the hoops I jumped through when I built my addition. However the inspector told me I over did everything. I over built the walls roof and my electric was good for an industrial shop. 14 separate 20A circuits for the garage alone. Everything was on GFIs. The only error I made was that I did not secure the Romex cables close enough to the power panel. That was an easy fix. I did have one GFI that would trip for no reason in the laundry room every now and then. Replaced it a couple of times and had a licensed electrician look at. All he could say is that there was no reason why it would trip, may be from lightning surges.
Old 07-27-2012, 06:58 PM   #27
E2 Electrician
I believe New Mexico is on the 2011 NEC...
Old 07-27-2012, 07:05 PM   #28
Master Electrician
One thing I always tell people is to ask your contractor to see the licenses of the people in his employ. Glad to see you only put a third down and very nice to see you want it done right. It's refreshing to see someone actually going above and beyond to NOT cut corners.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-27-2012, 07:06 PM   #29
I know it is old because they do stuff out here that would land you in jail in WI.
Old 07-27-2012, 07:09 PM   #30
E2 Electrician
It's not old, just not enforced.
Correct wire size? fatczech Electrical 6 12-18-2011 09:15 PM
What size breaker and wire ? baddley Electrical 6 02-15-2011 12:12 PM
What size wire to use running underground ms66cadillac Electrical 21 01-13-2011 12:14 PM
What size wire do I need? walnut777 Electrical 1 12-13-2010 07:41 PM
Wire size for distance Question fburke Electrical 4 07-28-2007 10:29 AM
