What Size Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2013, 07:34 PM   #1
What size wire
I'm remodeling n am adding a cooktop n a double oven. I was going to run 2 new seperate 6/3 wire for each. Is 6/3 ok or is it too much n I should go with 8/3 wire instead. I believe the cook top needs 30 amp n ovens 40 amp
ecocco1469 is offline   Reply With Quote
Old 08-02-2013, 07:42 PM   #2
PoleCat's Avatar
Rewards Points: 1,646
You can run the 30 amp in 10
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 08-02-2013, 07:43 PM   #3
Rewards Points: 62
what does the manual say?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
The Following User Says Thank You to digitalplumber For This Useful Post:
Kyle_in_rure (08-02-2013)
Old 08-02-2013, 09:03 PM   #4
Civil Engineer
Rewards Points: 4,770
#10 ==> 30A
#8 ==> 40a
If either of your units are 240 volt only (like some European models), you may only need 2 wire cable plus ground. As previously noted, read the manual carefully, follow directions on how to install.
New Sub Panel Wire Size? johnsas Electrical 4 08-29-2012 11:20 AM
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 09:38 AM
wire size for 160' feeder to subpanel steveski Electrical 3 05-21-2011 09:41 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
