What Size Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2012, 07:00 PM   #1
What size wire
I am adding a detached garage. I will be adding maybe a couple of 110 v circuits for outlets and one or two circuits for lighting. No 220v are planned. What awg should i run from my house panel?
Mule98 is offline   Reply With Quote
Old 09-01-2012, 07:12 PM   #2
Missouri Bound's Avatar
How far away is the garage? If you only need two circuits you can use (probably) 12-3 w ground. If you need more than that you will need to install a sub panel. You are only allowed one feeder to the garage. The distance will dictate the size. I would consider installing a sub panel for future considerations
Do you want it your way or the right way?
Old 09-01-2012, 07:16 PM   #3
Garage is 175 feet away. i plan on a small panel. will # 8-3/g suffice. also, i am using 1" pvc as conduit. can i use romex in this pvc
Old 09-01-2012, 07:24 PM   #4
Nope...no romex. You will need 4 wires; 2 hots, a neutral and a ground. You can use uf, but if you are installing conduit you may use individual wires, much easier to pull and accessable if you want to make a change in the future. You also have some issues you have to follow regarding grounding with the sub panel. Do you know what you need as far as amperage for the sub panel? That will help with the rest of the calculations.
Old 09-01-2012, 07:32 PM   #5
Licensed electrician
Rewards Points: 1,296
You need two hots, a neutral and a ground.
Missouri Bound (09-01-2012)
Old 09-01-2012, 07:33 PM   #6
Thanks...and I fixed it.
Old 09-01-2012, 07:33 PM   #7
i suppose then i should bury UF @24" Individual wires? Probably 8-10 duplexes and 6-8 flourescents( T-5 HDs i think) is all i need in garage.
what is the smallest sub panel on the market WILL #8 AWG WORK OR CAN I GET BY WITH #10 copper seems to be higher than gold!
New Sub Panel Wire Size? johnsas Electrical 4 08-29-2012 12:20 PM
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 10:38 AM
wire size for 160' feeder to subpanel steveski Electrical 3 05-21-2011 10:41 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 06:00 PM
