-   -   What size wire (http://www.diychatroom.com/f18/what-size-wire-155517/)
Mule98 09-01-2012 06:00 PM
What size wire
I am adding a detached garage. I will be adding maybe a couple of 110 v circuits for outlets and one or two circuits for lighting. No 220v are planned. What awg should i run from my house panel?
Missouri Bound 09-01-2012 06:12 PM
How far away is the garage? If you only need two circuits you can use (probably) 12-3 w ground. If you need more than that you will need to install a sub panel. You are only allowed one feeder to the garage. The distance will dictate the size. I would consider installing a sub panel for future considerations:thumbsup:
Mule98 09-01-2012 06:16 PM
Garage is 175 feet away. i plan on a small panel. will # 8-3/g suffice. also, i am using 1" pvc as conduit. can i use romex in this pvc
Missouri Bound 09-01-2012 06:24 PM
Nope...no romex. You will need 4 wires; 2 hots, a neutral and a ground. You can use uf, but if you are installing conduit you may use individual wires, much easier to pull and accessable if you want to make a change in the future. You also have some issues you have to follow regarding grounding with the sub panel. Do you know what you need as far as amperage for the sub panel? That will help with the rest of the calculations.:yes:
Jim Port 09-01-2012 06:32 PM
You need two hots, a neutral and a ground.
Missouri Bound 09-01-2012 06:33 PM
Thanks...and I fixed it.:thumbsup:
Mule98 09-01-2012 06:33 PM
i suppose then i should bury UF @24" Individual wires? Probably 8-10 duplexes and 6-8 flourescents( T-5 HDs i think) is all i need in garage.
what is the smallest sub panel on the market WILL #8 AWG WORK OR CAN I GET BY WITH #10 copper seems to be higher than gold!
