What Size And Type Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2013, 07:41 PM   #1
what size and type wire
I would like to run wire from a 200 amp panel at my house to a old barn about 250 ft away. I want it all underground and I'm going to use the barn as a workshop eventually. I'll have lights and several receptacles for power tools, all 110 volt no 220 volt, most powerful will be a standard table saw. How big a wire and what kind of wire will I need?
Will a 100 amp subpanel be enough inside the barn for receptacles and lights?
fyrchief is offline   Reply With Quote
Old 09-15-2013, 08:34 PM   #2
MarginallyQualified
Rewards Points: 2,464
It's about how many of those things will be on at the same time.
Should be.
Old 09-16-2013, 11:11 AM   #3
Rewards Points: 204
Depends on how much power you will need. But from your explanation, I would say 100 amp is plenty big.
Google "voltage drop calculator" to figure your wire size including voltage drop.
The distance is sufficient to up size the wire.
Old 09-16-2013, 02:59 PM   #4
Rewards Points: 366
like jv said you'll have to figure for voltage drop since it is such a long run. but while i was doing it , i would make it 240 volt. you may want buy a nice sized air compressor later.if ya don't you'll always have extra.what kinda sub panel were ya going to buy? i kinda like GE , but SQUARE D is top of the line in my opinon.
circuitman is offline   Reply With Quote
Old 09-16-2013, 05:15 PM   #5
i second the 240 volt panel. by the time you dig the trench, etc., it is pretty damn cheap to add the additional conductor.
the voltage drop is a function of how many amps you will actually be drawing. if you have 100 amps running at once (unlikely), you'll need something like a 250 kcmil copper conductor. if maximum is 60 amp, you could get by with a #2/0 awg. the cost difference between those conductor sizes is significant.
the above assumes thwn or similar cable type. uf cable uses different ampacities. what kind of cable are you looking to use.
itsnotrequired is offline   Reply With Quote
Old 09-17-2013, 06:05 AM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Typical job would be #2 XHHW AL. backed by a 90 amp breaker... sight unseen of course...
Wire size and type to use In2dux Electrical 5 09-29-2012 03:02 PM
What size and type wire should I use? Iman Electrical 4 06-20-2010 01:57 AM
Size and type of entrance wire for 200A? Beemer533 Electrical 7 03-15-2010 10:54 PM
Size of Wire & type of wire agman Electrical 6 11-10-2009 08:13 PM
Please confirm wire size and type for amperage. wantsomegetsome Electrical 14 05-07-2009 05:49 AM
