What Size Ground Wire Do I Need? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 09:49 PM   #1
What size ground wire do I need?
I am replacing a 100A old ZINSCO circuit breaker panel with a new SQUARE D 200 Panel. What size of grounding rod do I need and what size ground wire should I use?
Jmanallbay is offline   Reply With Quote
Old 01-04-2012, 10:04 PM   #2
jproffer's Avatar
Rewards Points: 706
2-5/8" x 10ft ground rods...at least 6 feet apart.
and.....(I'm hesitating because I'm only 95% sure on this one)........#4 grounding conductor....I think.
I've always driven the ground rods at an angle toward each other...and I hear laying them down is even better.
jproffer is offline   Reply With Quote
Old 01-04-2012, 10:14 PM   #3
Licensed electrician
Rewards Points: 1,284
Your rods only need to be 8', all of which is in contact with the earth.
The conductor to the rod does not need to be larger than #6. It should not be subject to damage.
Six foot apart is the minimum, more is better.
Old 01-04-2012, 10:22 PM   #4
jproffer's Avatar
Rewards Points: 706
So close, lol. I guess if I'm going to be "off" oversized is better than undersized.
Old 01-04-2012, 10:29 PM   #5
I always run #4 to the rods. That way I don't need to keep two reels on the truck.
Old 01-04-2012, 11:25 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
I hope you are not just replacing the panel. I hope this is a service upgrade.
Light switch - Taping into ground wire ok? SimpleJack Electrical 2 08-15-2011 08:04 AM
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 10:38 AM
220 Ground wire size. Giles Electrical 2 01-30-2010 09:22 PM
Panel ground and wire size tns1 Electrical 25 09-18-2009 03:53 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
