What Size Dimmer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 01:07 PM   #1
I want to add a dimmer on my four, 100 watt, ceiling lights. The dimmers come in 300, 600, 1000 watt sizes. Do I only need to add 100 * 4 = 400 and get the next watt size that covers it, in this case 600, or is there more to consider?
Sent from my iPad using DIY Forum
MikeInDetroit is offline   Reply With Quote
Old 11-10-2011, 01:12 PM   #2
Rewards Points: 6,652
You size for the total wattage on the circuit, and add some for overhead, so that you do not burn out the dimmer.
Old 11-10-2011, 02:12 PM   #3
Licensed electrician
Rewards Points: 1,234
Also please note that if you have more than one dimmer in the same box you will need to derate the dimmer. The derated value is normally on the dimmer near the breakoff tabs.
Old 11-10-2011, 04:07 PM   #4
Rewards Points: 502
modern dimmers are not resistance based, the are pulse width based. There should be very minimal heat production with them.
forresth is offline   Reply With Quote
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Changing from dimmer to regular switch..help!!!!!!!!!!!!!!!!!!!!!!! Gomezy3k Electrical 8 10-04-2010 04:26 PM
Dimmer Switch Question Livewire78 Electrical 6 01-03-2010 10:51 PM
Need help installing a dimmer switch { PICTURE } Brieninsac Electrical 8 11-20-2008 01:25 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
