Old 11-23-2010, 11:53 AM   #1
what size conduit
well, here goes, I will be installing a 12 full circuit main lugs only
sub panel in a attached garage, plan on only using up to 4 to 6
circuits at tops, but, will have some space for possible future.
Can you please advise what size EMT conduit that the code requires.
Plan on pulling four ( 4 ) # 6 Thhn copper wires, white, black, red,
and a green, I was hoping to get by with 3/4 ", but will that be
up to code. ? ? note: I am planning on getting a rating of
60 or 70 amps, that will be plenty for what we need.
I am reasking this question, as last time made no mention that the Garage was attached, my fault , I do appreciate your reply's.
Thanks PIGEONS
PIGEONS is offline   Reply With Quote
Old 11-23-2010, 05:38 PM   #2
what size conduit
3/4 will be ok.also use a #8 green for ground,will be plenty.
oleguy74 is offline   Reply With Quote
Old 11-23-2010, 07:28 PM   #3
" Euro " electrician
frenchelectrican's Avatar
what size conduit
3/4 inch EMT conduit will work with 16mm˛ conductors { AKA #6 AWG } that good for 60 amp but if you plan to boost it up to 100 amp down the road then you have to bump the conduit to 1.25 inch conduit { I know 1 inch can be doable but not worth a hassle } with 35mm˛ { #2 AWG } copper THHN/THWN
Merci.
Marc
wire size for conduit run WDR Electrical 25 08-07-2010 11:38 AM
is UG conduit size change legal? krazni Electrical 1 07-13-2010 03:17 PM
Sealing conduit coming into house encased with waterline pacamaroman Plumbing 3 06-18-2009 09:48 AM
Running conduit for a pool light KyMike Electrical 12 06-17-2009 04:02 PM
What size wire and what kind of conduit... epeterson777 Electrical 15 02-21-2009 08:43 PM
