What Size Conduit For 4/0-4/0-2/0-#4 - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 03:36 PM   #1
RPN
What Size Conduit for 4/0-4/0-2/0-#4
Getting ready to run 150' of 4/0-4/0-2/0 URD and a #4 EGC.
It will have two 90s and two 45s.
Waffling between 2.5" and 3" conduit.
Your thoughts?
RPN is offline   Reply With Quote
Old 11-15-2011, 04:07 PM   #2
3" is better. You always want to give yourself extra room in conduit if you have the space to run it. It is better to have extra room than not enough and make it hard to pull the wire thru.
eridia is offline   Reply With Quote
Old 11-15-2011, 04:35 PM   #3
RPN
That was my thought also. It is only another $45 or so of conduit.
The only issue is that I have to connect to a 2.5" LB (conduit body) and I don't have any readily available 3"-2.5" reducers.
However, I do have a 3"-2" reducer. I may use that, run a few inches of 2" at the end and sleeve some 2.5" over the 2" to act as an expansion for frost heave.
What conduit should I use? mulltron Electrical 6 07-12-2011 01:34 AM
Conduit Size Believer Electrical 1 07-11-2011 03:19 PM
wire size for conduit run WDR Electrical 25 08-07-2010 10:38 AM
is UG conduit size change legal? krazni Electrical 1 07-13-2010 02:17 PM
What size wire and what kind of conduit... epeterson777 Electrical 15 02-21-2009 07:43 PM
