What SE Wire (new Service) - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-23-2012, 09:15 PM   #16
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Just saw your last post. Coops are owned by the customers ... Guess you can do anything you want ...
As Kbsparky said 4/0 aluminum hots, 2/0 neutral and #4 ground. Do you know your burial depth?
Old 08-23-2012, 09:27 PM   #17
Rewards Points: 91
i was going to go atleast 18inches depth (possibly 24inch) as I will be doing the trenching myself with a trencher. Don't know that it would make a difference as I am going to run it through 2in pvc conduit.
Does this seem like a good plan?
I have an electrician that is a friend of ours that is going to do the actual hookup, and hookup our ac. However I want to make sure that this setup will work.
no_Wedge is offline   Reply With Quote
Old 08-23-2012, 09:44 PM   #18
UAW SKILLED TRADES
Stubbie's Avatar
Yes it makes a difference ...Go 24 inches minimum to be safe. 2 inch pvc is fine.
Old 08-23-2012, 09:47 PM   #19
UAW SKILLED TRADES
Stubbie's Avatar
Does the panel in the MH have a main breaker ?
Old 08-23-2012, 10:19 PM   #20
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Funny. I think you are realizing that the "hook ups" are the easy part, and the part you want to do is the hard/technical part.
Old 08-24-2012, 11:58 AM   #21
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
Just have the coop install a pole close to the home and then install the disconnect there.
That's how it is done in my area.
Old 08-24-2012, 05:11 PM   #22
Rewards Points: 91
yes it has this box
http://www.homedepot.com/buy/electri...l#.UDf4KcFlSSo
with a 200 amp 22KA circuit breaker.
I noticed that all the current old main wires, are 2/0 gauge. This would be too small for this type of application, would it not?
Old 08-24-2012, 05:20 PM   #23
Rewards Points: 3,256
Are these customer wires or coop wires?
zappa is offline   Reply With Quote
Old 08-24-2012, 05:26 PM   #24
Rewards Points: 91
these are the previous owners wires. not the coop.
Old 08-24-2012, 05:26 PM   #25
Rewards Points: 91
these are the previous owners wires the ones that are still connected in the house panel. not the coop.
Old 08-24-2012, 05:28 PM   #26
Yeah, too small. Is it even a 200 amp panel?
Silly me....I see you mentioned a 200 amp panel.
Old 08-24-2012, 06:10 PM   #27
Rewards Points: 91
ok so how does this sound to everyone.
run 2-4/0 hots, 1-2/0 neutral, and a #4 copper ground from the main disconnect to the house's main panel in 2" conduit buried at 24" deep.
Am I correct in stating that the ground doesn't need a rod of it's own since it is connected to the disconnect at the pole?
Old 08-24-2012, 10:13 PM   #28
UAW SKILLED TRADES
Stubbie's Avatar
No those are aluminum sizes the original wires are probably copper.
We use a certain table for main power feeders
For 200 amps and Aluminum mobile home feeder use 4/0 hots, 2/0 neutral and #4 ground
Old 08-24-2012, 10:18 PM   #29
Missouri Bound's Avatar
deleted
Do you want it your way or the right way?
Direct burial wire for 100 amp service caugen Electrical 4 01-03-2017 07:53 AM
service entrance wire michaeljack Electrical 4 10-27-2011 12:25 PM
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
New upgraded 200A service wire connections WillK Electrical 1 04-28-2011 02:02 PM
Can I wire a new panel without service or run a "big" subpanel? tigereye Electrical 7 03-03-2009 04:00 PM
