What’s The Problem ??? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2011, 07:27 PM   #1
What’s the Problem ???
Hi
I have a single pole 15 amp light switch for my front porch light; it is wired as a middle-of-the-run switch. The switch doesn’t always work.
Sometimes I can bang on the wall with the switch on, and it will activate the light.
I tested with a voltage tester.
A book I read said that touching one tester to the metal box and one to the black hot wire should light the voltage tester, it does not. If I touch one tester to the white and one tester to the black it does light the voltage tester.
I even attempted with a new switch with no differences.
What’s wrong with this wiring?
MurphsWorld is offline   Reply With Quote
Old 11-29-2011, 07:36 PM   #2
Electrical Contractor
kbsparky's Avatar
Probably a loose or bad connection in the light fixture if replacing the wall switch did not correct the problem.
-KB
The Following 2 Users Say Thank You to kbsparky For This Useful Post:
gregzoll (11-29-2011), MurphsWorld (11-29-2011)
Old 11-29-2011, 08:18 PM   #3
Hi,
Thanks...but...why doesn't the voltage tester light up when I touch one end to the hot black wire and the other to the metal switch box?
Doesn't that speak to an issue with proper grounding?
Old 11-29-2011, 08:43 PM   #4
Rewards Points: 115
it shows there is no ground in the box. not uncommon in older homes. if you are getting proper voltage between black and neutral you probably have a bad connection/splice in light fixture. flip breaker off and check for loose wires in fixture
pokey is offline   Reply With Quote
The Following User Says Thank You to pokey For This Useful Post:
Old 11-29-2011, 09:20 PM   #5
Thanks Guys!!
Yeah...appears to be something in the line to the light fixture.
Tore it down...and it has the old knob and tube wiring behind the fixture!!
Though the switch to it is wired with standard wiring??
Lord knows where in the wall / ceiling it reverts back to the knob and tube!
Old 11-29-2011, 09:53 PM   #6
Rewards Points: 6,652
Good ole fire starter. I would try and get as much replaced with romex, starting this weekend if you can. Have the walls been insulated, does the attic still have K&T, with insulation over it?
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 09:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
