Old 05-31-2008, 03:12 PM   #1
Question
What is required to eliminate electric from office wall?
I am wondering what is required to completely remove electric service from an office wall that is being removed. This is in Illinois and am bidding a job to remove 2 walls, preform drywall work/paint and am wondering if a licensed electrician needs to perform this type of work and if a permit/ inspection would be involved.
The walls are 8' steel stud with a couple of outlets and a blank plate in them with a drop ceiling above. Does the wiring need to be taken out all the way back to the junction?
Any help would be appreciated!
Thanks!
flatlander745 is offline   Reply With Quote
Old 05-31-2008, 03:45 PM   #2
Power Gen/RS Engineer
You'll need to remove the wire at minimum back to the nearest exposed junction point. It is not difficult to remove the conduits and boxes since you'll likely find that all connectors are set screw type. The big question is, why does the owner want the recepts removed? If the owner did not object, you could rock over the existing boxes and install blank covers (in this case, you don't even need to remove the wire). Then if they want recepts in the future, it will be very easy to add them.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
BigJimmy is offline   Reply With Quote
Old 05-31-2008, 04:05 PM   #3
I suggest hiring an electrician for this one. It could be an easy job and it could turn out to be a pain in the ass depending on what those boxes might be a junction for. If they are the end of a branch then you're fine but they could have something else branching from them.
Super33 is offline   Reply With Quote
Old 05-31-2008, 05:29 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Since you are in Ill I would suspect you need a licensed contractor and permits.
DO NOT attempt this job yourself in this commercial environment.
Old 05-31-2008, 11:37 PM   #5
Sometimes it's easy and sometimes it's not.
I hope that helped
It could be a matter of simply disconnecting some MC run down the wall. If there is a grid ceiling, access will be easy enough. If it's a hard lid, your job just got harder. If you take off a neutral wirenut on a MWBC during the simple demo, your profit margin may get blown very quickly.
220/221 is offline   Reply With Quote
Old 05-31-2008, 11:41 PM   #6
That's for sure, it could be.... priceless
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
