What PVC Cement Should I Use For 3" Schedule 80 Conduit? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2012, 02:26 PM   #1
Rewards Points: 508
What PVC cement should I use for 3" schedule 80 conduit?
Will this stuff work for 3" schedule 80 conduit? http://www.oatey.com/Channel/Shared/...ar+Cement.html
No primer, right?
benjamincall is offline   Reply With Quote
Old 03-21-2012, 05:18 PM   #2
liscenced electrician
Rewards Points: 538
No primer, right?
Heavy Duty Clear cement for use on all schedules and classes PVC pipe and fitting up to 12 diameter with interference fit, up to 18 for non-pressure.
Taken right off your link. Yes its good. No primer needed
jimmy21 is offline   Reply With Quote
The Following User Says Thank You to jimmy21 For This Useful Post:
benjamincall (03-22-2012)
Old 03-22-2012, 07:46 AM   #3
Rewards Points: 508
Thanks. I know Carlon makes a cement specifically for conduit, so I wanted to make sure that statement from Oatey encompassed the grey stuff. On a side note, isn't a cable pull satisfying, especially when you cover a long distance?
Old 03-22-2012, 09:27 AM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I use primer not sure it helps but just habit and it's what I have always done.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Attaching 2" Schedule PVC conduit to the bottom of a mobile home rrolleston Electrical 2 01-25-2012 08:54 PM
safety near house power line conduit ChrisJJ Painting 7 08-13-2010 10:44 AM
How to plug unwanted and leaking conduit? gernith General DIY Discussions 6 08-08-2010 01:09 PM
Sheathing/siding around conduit destroyer427 Building & Construction 1 10-20-2009 06:25 PM
ground wire in rigid conduit measure thrice Electrical 3 02-03-2009 06:25 AM
