Old 07-11-2012, 05:11 PM   #1
What parts do I need to make this lamp?
Hello everyone. Thanks for reading this and offering suggestions.
I found this lamp awhile ago online. It sells for an outrageous $150. I want to try to make it myself.
But I don't know what parts I would need to do so. I've never tried much electrical work, but I think I'm handy enough that if I had the parts I need then I could figure out how to make it.
So I'm soliciting help from y'all. What type of toggle switch is that? Where can I get one? Is that most likely a normal light bulb socket? What kind of wiring is going on inside of this (most likely)?
Any help is much appreciated. Thanks again for reading.
ChrisM6484 is offline   Reply With Quote
Old 07-11-2012, 05:40 PM   #2
MarginallyQualified
A porcelain base for the light bulb, toggle switch and a cord set
Everything is available at any decent hardware store.
TarheelTerp is online now   Reply With Quote
Old 07-12-2012, 09:40 AM   #3
Thanks for your answer.
Would I need a DPST or SPST toggle switch for something like this?
Old 07-12-2012, 10:00 AM   #4
Spst.
LooseSCruz is offline   Reply With Quote
Old 07-12-2012, 10:04 AM   #5
Why even bother with that ugly switch sticking out?
Just install a switch on the lamp cord.
Old 07-12-2012, 10:23 AM   #6
Master Electrician
Does anyone else think there may be an issue with creating a fixture out of paper?
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-12-2012, 10:26 AM   #7
Sure not going to meet any UL rating on this planet.
Bare bulb, using a lamp holder that has exposed wiring on the back side close to a flamable material. And just plan ugly to look at.
Old 07-12-2012, 10:46 AM   #8
This one is only $3200.
M Engineer is offline   Reply With Quote
Old 07-12-2012, 10:48 AM   #9
This is a great idea. I would to have one. Could you share you thoughts and maybe a piece of advice when you've done yours. Thanks
garethcooper9 is offline   Reply With Quote
Old 07-12-2012, 12:11 PM   #10
Electrical Contractor
It must be the lamps that have the appeal.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 07-12-2012, 05:08 PM   #11
I would worry about the flammable material as well. A UL listing, however, is only necessary if the OP wants to sell it.
ionized is offline   Reply With Quote
Old 07-12-2012, 05:14 PM   #12
Thanks to everyone who's replied so far. This has been a good learning experience for me.
I went to a hardware store today and found all the pieces I need to make this work:
- E26 porcelain socket
- SPST toggle switch (15 amp)
- lamp wiring cord w/ plug
I'll probably go get a book and start carving that up tomorrow.
Would it not be safe enough if I just made sure all exposed wires are wrapped well in electrical tape?
Old 07-12-2012, 05:45 PM   #13
No, I would not want that in my home or workplace. Sparks from the connections on the back side of the socket could easily ignite the paper. Connections are the weak and most dangerous place for line power.
I think what you need to do is enclose the back side of the socket in a small box like a junction box. Enclose most of the socket. Gut enough of the paper from the book to make room for the box. Install the cord through the side of the box with a strain relief so there is nothing left open.
Better yet, install a lamp socket like on the suspended bulbs in the pic posted by M engineer. That way, all the connections are in the open, but under the metal. You will have only cord running through the book and you won't have to gut so much of the book.
Old 07-12-2012, 06:15 PM   #14
Master Electrician
can i use that as my new quote in my sig?
Old 07-12-2012, 07:10 PM   #15
@andrew79
Absolutely. My only request is attribution and a small fee of $1 each time you use that sig.
Best way to make a roof exit or door? swaff Roofing 5 10-22-2010 02:15 PM
Best way to make 45 degree mitre jig BobS0327 Carpentry 7 09-22-2010 12:53 AM
Do parts people make you mad? Thurman Automotive Repairs 18 07-09-2010 11:22 PM
electric wiring for fluorescent lamp toronbolo Electrical 3 03-24-2008 01:16 PM
Using a european lamp in the States mattlima Electrical 3 03-16-2008 09:12 PM
