What Is This Light Switch Called? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2011, 10:45 PM   #1
Rewards Points: 150
What is this light switch called?
Need a keyword so I can search how to wire it. Assume there's something in there that acts like a pigtail to connect two separate switches, but maybe I'm wrong. Do they still make these?
http://www.electrical-picture.com/wp-content/uploads/2011/4/14/how-to-wire-double-light-switchin.jpg
(I'm rewiring a circuit in my house from K&T.)
Thanks, Nancy
NancyNGA is offline   Reply With Quote
Old 08-22-2011, 10:54 PM   #2
Code05's Avatar
Rewards Points: 1,104
twin single pole toggle, I will find a link.
Code05 is offline   Reply With Quote
Old 08-22-2011, 11:01 PM   #3
Code05's Avatar
Could also be a 3 way combo.
http://www.leviton.com/OA_HTML/ibeCC...minisite=10021
2 screws both sides, not including the green one?
Old 08-22-2011, 11:05 PM   #4
Rewards Points: 150
Yes. It connects to two separate lights, both on the end of a circuit.
Old 08-22-2011, 11:08 PM   #5
Rewards Points: 6,652
Lowe's has both the Decorator style of that switch, and the paddle toggle. Both are Cooper Switches. Btw, they are called "Combination switches."
http://www.lowes.com/pd_70590-334-27...ring%20Devices
http://www.lowes.com/pd_7732-334-772...ices|Decorator
The Following 2 Users Say Thank You to gregzoll For This Useful Post:
Code05 (08-22-2011), NancyNGA (08-23-2011)
Old 08-22-2011, 11:19 PM   #6
Code05's Avatar
Just to be safe, was the tab between the screws on the left screws intact?
1 black wire in and 2 black wires out or what? On the switch.
Old 08-22-2011, 11:55 PM   #8
" Euro " electrician
frenchelectrican's Avatar
That called combo switch it will come in either rocker or toggle verison and diffrent colours as well.
Just watch out they will come both single pole verison or one single pole and one three way or two three way verison.
However just give you a head up if you go with combo switch make sure you get a deep well single gang box due the numbers of wires will fill it up fast.
Otherwise a 4X4 box with single gang mud ring will work just perfect on this purpose { there are few depth verison of mudring so if you have 1/2 inch drywall then get 7/16 or half inch mudring they will have it in stock in most big box store and hardware store }
IIRC they were about 10 Euros or so { the last time I have to get one with polit light so it was 15 Euros so expect in that price range }
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 08-22-2011, 11:59 PM   #9
Rewards Points: 150
Yes, I think it's intact, if you mean the A shaped copper tab in the middle:
Thanks to the keyword combo, I was able to Google it and found what I wanted. And yes, there were 2 black wires on one side and 1 on the other, but I forgot to write down which side before I took it out. Now I know to look for the +LINE+ on the side.
Sorry for asking silly questions. You guys are great!
Old 08-23-2011, 12:04 AM   #10
Rewards Points: 150
frenchelectrician, I'm going to use the same switch if possible. It's fairly new. See the little white tabs on the screws? They didn't used to do that. Thank you.
Old 08-23-2011, 12:15 AM   #11
That will be fine to use that exsting switch.
As you noted redish brass screw that is for incomming power { black wire } while at the second photo where you have bright brass colour screw that is outgoing to light or fan.
Tie all the netural conductor { white wire } with either yellow or red wirenut depending on the conductor size.
Ditto with grounding { bare copper wire } as I highlighted with netural but one more step you will have to bring one bare copper wire to sliver screw on the photo.
then you are all set to go.
If any more question just holler one of us will help you on this one.
Merci,
Marc
Code05 (08-23-2011)
Old 08-23-2011, 12:59 AM   #12
I could not even remember the specific of what they are called, until I did a search through lowes.com.
Old 08-23-2011, 08:26 AM   #13
Rewards Points: 1,514
The A shaped copper tab between the two reddish screws is to allow the convenience of one hot wire feeding both switches and lights.
If by chance that tab got broken off by accident then you would need two hot wires (cut two short lengths aka pigtails, wire nut them to the single hot wire, and now you have two hot wire ends for the two reddish screws). The A shaped tab would be intentionally bent and broken off if the two switches and lights will be fed by different circuits each with its own hot wire.
The bent up metal edges near but not right next to the light gold screws serve no purpose.
The white cardboard tabs on the mounting screws keep the screws from getting lost prior to mounting. YOu would remove them only if you have a metal box and use a special grounding clip (sold separately) to permit just one ground wire for both switch and box
Old 08-23-2011, 08:39 AM   #14
Rewards Points: 150
OK, one more question....
If I wanted to extend this circuit to include, say, an always-on-receptacle down the line, could I just attach the hot wire going to the receptacle to the other terminal on the +LINE+ side of the switch (as long as the tab is not broken), or do I have to make a separate pigtail?
Old 08-23-2011, 09:41 AM   #15
Code05's Avatar
You could, but pigtail is more standard.
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 09:20 PM
3 way light switch issues Chizl Electrical 7 04-25-2011 04:01 PM
Blown Light Switch ogrenjr Electrical 3 03-01-2010 03:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 12:17 PM
