What Kind Of Wire Is This? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-31-2013, 06:54 PM   #1
Rewards Points: 150
I rewired my house about two years ago. The way I rewired it was I built two additions on to my house and added a new 200 amp service and main panel. my buddy gave me the wire which is from around 1988 which is why it's not color coded. Anyway, in the first picture is my main panel which the wires go up through the floor up the wall and up to the attic, over to the other side of the house and back down into the old part of the house which I kept the old fuse panel and the existing lines connected and just wirenuted my new wires to the old for now so i have power in the old part of the house until I can get around to completely rewire the old part. Some of my circuits for the other addition juction in here too which I have connected to multi branch circuits. I know the armored cable is bx but what is the green sheathes cable. I thought green cable was aluminum but I don't remember seeing aluminum.
What kind of wire is this?-image-3187829452.jpg   What kind of wire is this?-image-2011906016.jpg   What kind of wire is this?-image-2583427938.jpg   What kind of wire is this?-image-1216423494.jpg   What kind of wire is this?-image-1595664509.jpg
romex1220 is offline   Reply With Quote
Old 07-31-2013, 07:41 PM   #2
Civil Engineer
Rewards Points: 4,956
That green sheathed cable looks a lot like the Romex I have in my house, which dates to 1959.
Daniel Holzman is online now   Reply With Quote
Old 07-31-2013, 08:13 PM   #3
Rewards Points: 150
Yeah that's exactly when the old part was built. I just verified that its copper wire but I've never seen green cable except for aluminum wiring. I actually need to replace it soon because alot of the sheathing is cracked cause its rubber and I just don't like old wiring. I wanted to replace it when I rewired but I just didn't have the time and money and I have lath and plaster and didn't want to mess with that at the time so I just temporarily hooked up the old to new
Old 08-02-2013, 10:50 AM   #4
Electrical Enthusiast
Rewards Points: 504
I've seen that in a lot of houses around here that were built in the 1960s. I've only seen it in Copper.
Kyle_in_rure is offline   Reply With Quote
Old 08-03-2013, 07:42 AM   #5
Rewards Points: 150
And this wire also has a ground. I thought they didn't come out with an equipment ground until later
Old 08-03-2013, 07:57 AM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
1956 NEC they started requiring grounding receptacles, all wiring methods probably followed that same time frame.
The Following 3 Users Say Thank You to stickboy1375 For This Useful Post:
Kyle_in_rure (08-03-2013), MTN REMODEL LLC (08-03-2013), RocketGal (08-19-2013)
Honeywell vision pro, fan always on? and True Steam problem c5sb HVAC 6 06-19-2012 09:08 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
What size wire and what kind of conduit... epeterson777 Electrical 15 02-21-2009 07:43 PM
