What Kind Of Recessed Lighting And Bulb? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2011, 08:59 AM   #1
What kind of recessed lighting and bulb?
Hi, we are starting to remodel our old house and after took down a couple of walls finally we are going to have a big open living room. We want to install 8 recessed light on this room (the size of the room is 25 x 14 x 8), our attic have a R11 fiber glass insulation and just we are not sure about the right recessed kit to buy and what kind of bulb to use. Personally I really like the halogen for the clear light that they emitted, just not sure if they are good for general lighting, and someone says that they get to hot. I was thinking to use the Commercial Electric 4 in. Non-IC Remodel GU10 Recessed Lighting Kit (K20) from Homedepot all connect to 3 dimmer switches and one 15A breaker. Any suggestion? Thank you
Sardinia is offline   Reply With Quote
Old 01-28-2011, 10:36 AM   #2
Rewards Points: 1,668
You can't use non-IC rated fixtures with insulation there. As you likely don't want to have 8 holes in your ceiling allowing hot air out to the attic, you'll need to find IC-rated fixtures. Back to the drawing board.
bob22 is offline   Reply With Quote
Old 01-28-2011, 11:03 AM   #3
That's a pretty large room for only eight 4" fixtures, unless you have other lighting in the room. As a general rule of thumb, a 6" can will spread a beam about 7' in diameter from an 8' height. For general downlighting, cans should be spaced about 2.5' away from walls and roughly 5'-6' from each other in the center of the room. That's more like 20-24 cans.
I'd look for air-tight, IC-rated 6" fixtures. This will allow you to cover the can with insulation and minimize air leakage from the conditioned space in the living room.
clashley is offline   Reply With Quote
The Following User Says Thank You to clashley For This Useful Post:
Sardinia (01-28-2011)
How to remove trim from Halo recessed lighting?? rdiggidy Electrical 7 09-05-2013 06:00 PM
recessed lighting problem twild Electrical 6 11-23-2010 07:57 AM
Cover for Recessed Lighting Trim Model HBR635(T49) aghahary Electrical 4 07-23-2010 04:30 PM
Recessed lighting problem (a real tough one) bavenda Electrical 4 12-07-2008 10:11 PM
Bathroom Recessed Lighting Pineapple Electrical 6 03-03-2008 07:51 PM
