What Kind Of Connection Is This? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-26-2013, 10:36 PM   #16
Rewards Points: 1,628
Originally Posted by gregzoll View Post
Yep, jack was for a Home Alarm system, that used wireless units at windows and doors. Could tell from Picture 3 that it was a RJ31x jack.
You can replace that jack with a RJ-45, if you want a Ethernet Jack, or unhook and start pulling. Most likely once you get it loose at each jack, the cable will pull right out of the wall.
If it's for an alarm system, does it make sense that there are two of these cables that ran parallel for over 80' outside? Also these jacks are only found under two windows out of a total of eight windows?
miamicuse is offline   Reply With Quote
Old 12-27-2013, 08:32 AM   #17
Rewards Points: 6,652
It depends on who ran the wiring, and why. Most likely previous home owner did it. Now if they used it for Alarm Sensors, that would make sense why they ran them under the windows. Most likely had a 1000' reel of Ethernet Cabling, and instead of purchasing the proper wiring, they just used what they had.
Old 12-27-2013, 08:38 AM   #18
PoleCat's Avatar
Rewards Points: 1,646
I would be more inclined to think that is the remnants of a LAN. Every cable is a home run to the switch/router.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 12-27-2013, 09:41 AM   #19
Not in that setup, and the fact that Jack is not a RJ-11, most likely a RJ31x for a Security system.
Old 12-27-2013, 11:48 AM   #20
joed's Avatar
Rewards Points: 12,872
Seems odd to have a security system with elements could be simply unplugged. How secure is that?
Old 12-27-2013, 12:05 PM   #21
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Why not just tone them out and see where they terminate instead of listening to a bunch of people guess at a picture?
The Following User Says Thank You to stickboy1375 For This Useful Post:
Jim Port (12-27-2013)
Old 12-27-2013, 12:24 PM   #22
You have to have a RJ31x jck, in order to connect it to the phone line. It has been that way for decades, and has worked fine.
Old 12-27-2013, 02:33 PM   #23
Rewards Points: 91
I doubt it is anything connected to an alarm system or it would NOT be in the open. It would be tucked away in a closet, etc. That's where I have been putting them for years and years. More than likely just a two-line phone/phone or phone/fax setup from years past.
Not uncommon to see telephone line installation on outside of building.
Just my humble opinion from experience in the field.
George6488 is offline   Reply With Quote
The Following User Says Thank You to George6488 For This Useful Post:
stickboy1375 (12-28-2013)
Old 12-27-2013, 05:25 PM   #24
You would be surprised what you see with some of these knock on the door to get you to sign up for their alarm service places do their installs. I have seen some homeowners do the same thing.
Also Telephone & Fax does not use a RJ31x jack.
Old 12-27-2013, 07:51 PM   #25
Good point, to which I answered in the very first post of this thread.
blah blah blah...
I did try and trace from under the eave to the other end to see where both cables go, but unfortunately I got it all the way to the other side of the building and they both went inside the concrete wall again to the mechanical/electrical room, and a bunch of other cables go in there too, and inside that room where the cables penetrated, is a huge metal shelving unit with a bunch of junk blocking most of the wall and I can't see what's behind unless I start moving everything out of the way.
Old 12-28-2013, 04:25 PM   #26
Rewards Points: 320
(1) Get rid of it. Pull off these jacks and push the cable into the wall cavity. Patch the small hole on the sheetrock and pretend they are not there. If a tenant wants a land line or DSL service, they can contact the phone company and have them come out and they would most likely run a new line.
(2) Replace the jacks and rewire it to something usable and I am not even sure what this is .
(3) Leave it and when a tenant ask me "what is this for?" I say "it's some kind of a jack"
I wouldn't remove the wire if it is run neatly and out of sight. If you remove it and the tenants call the phone company there is a good chance that they will send out some hack who will drill holes through your exterior siding and run the wires on the outside of the house.
Cut the jacks off and wire up some new phone jacks.
teamo is offline   Reply With Quote
Den and hallway, same kind flooring or different kind of flooring Pau-Latina Interior Decorating 9 10-09-2013 02:48 PM
What kind of cable is this? Sith717 Electrical 3 03-10-2012 01:56 PM
vent hood electrical connection question cbendock Electrical 4 02-12-2011 10:33 PM
Dripping washing machine connection icespide Plumbing 4 11-11-2010 08:41 PM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 06:10 AM
