Old 12-17-2008, 09:31 AM   #1
What kind of Circuit breaker??
EDIT: Found out its a cutler hammer.
Does anyone know what kind of Circuit Breaker this is? I need to have some work done, and I can't make it home for another 8 hours... all I have is the pictures attached. The install date on the green sticker says 1990 - if that helps.
What kind of Circuit breaker??-dscn1284.jpg   What kind of Circuit breaker??-dscn1285.jpg
baist111 is offline   Reply With Quote
Old 12-17-2008, 09:42 AM   #2
My License Ain't 4 Sale..
Those are Cuttler Hammer type CH.
Old 12-17-2008, 12:27 PM   #3
DIY'er
jamiedolan's Avatar
FYI: You should have the main turned OFF when you remove or replace the cover on your panel. There is a arc flash hazard when removing / replacing covers.
If your doing the work yourself, these breakers are available at home depot, Menards, etc. for about $6 each. If your hiring an electrician, allow them to supply the necessary breakers, this is a very common one and they should have it in there truck.
Jamie
Jamie Dolan - Neenah, WI
Need Help Uploading Photos?
jamiedolan is offline   Reply With Quote
Old 12-17-2008, 12:37 PM   #4
Jamie
Thanks for the replies...
I'm actually without power at this point because the main breaker is stuck in the off position - that's why the panel is off.
I'm being very cautious I've hear a lot of bad stories - I have an electrician coming to the house this afternoon, I just wanted to let him know everything ahead of time so that he could come well prepared.
Old 12-17-2008, 12:47 PM   #5
DIY'er
jamiedolan's Avatar
I would have him check that your panel is properly grounded as well. I don't see a ground wire coming out of your panel at all, but I might just not be able to see it in the photo. If it was installed in 1990, I am pretty sure they would have required grounding rods at that point to be connected, as well as bonding to the water pipes if they are copper. A few wire staples on the loose wires around the outside of the box would be a very good idea as well.
Good Luck with the repair.
Jamie
Heat pump circuit breaker pbms pinkertonpv HVAC 11 02-18-2009 10:47 AM
Old Electric Panel/ Circuit Breaker Box dankreboot Electrical 3 12-16-2008 01:52 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 09:38 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 04:09 PM
