What Kind Of Can Light Is This? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-05-2012, 11:33 PM   #1
Rewards Points: 308
What kind of can light is this?
Picked up three of these at the Restore for $5 a piece--I've been wanting to add three to the soffit near my patio to light it. I don't really know anything about these fixtures (and can always return them), but was hoping someone on here could help tell me what kind they are and how I would mount them. They are about 4" in diameter, and the bulb is a small incandescent about 1" in diameter. Here is a picture--has some clips on the sides that I assume are to mount with. Please advise.
smokey847 is offline   Reply With Quote
Old 06-07-2012, 11:34 PM   #2
Rewards Points: 308
It uses this kind of bulb. What is this kind of can best used for? Is it 120v?
http://www.homedepot.com/Electrical-...&storeId=10051
Old 06-08-2012, 09:26 AM   #3
Licensed electrician
Rewards Points: 1,054
That is a very inexpensive remodel recessed light housing.
Old 06-08-2012, 07:23 PM   #4
Rewards Points: 308
Thanks for the info. I'm looking to mount the three of these in the soffit near my patio to light it up. Any ideas on how they mount? If you look closely, you can see metal spring things on the side. Doe these need a housing, or just a hole and they'll hold themselves in?
Old 06-08-2012, 07:35 PM   #5
Rewards Points: 12,882
I doubt you even be able to fit them in a soffit, there to tall.
Also it looks like there a remodel light not a new constrution, which means there made to snap into a sheet rock ceiling not a soffit.
Old 06-08-2012, 09:00 PM   #6
Just a DIY guy
Nice to see people using Restore, but recessed light cans are quite cheap, under $10 for new construction, and under $20 for retrofit. They come with instructions, take normal bulbs, etc.
M3 Pete is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
Wiring issue on light wkuengineer Electrical 9 06-03-2012 03:08 PM
Light Wiring Question mataguri Electrical 4 11-09-2011 03:15 AM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
