What Kind Of Bulb Is This - Electrical - DIY Chatroom Home Improvement Forum
Old 08-29-2012, 03:32 PM   #1
What kind of bulb is this
Can anyone please tell me what kind of bulb this is or where I can get a new one? It is a low voltage bulb, but I a cannot find anything with this base. I have attached images.
What kind of bulb is this-get-attachment.jpg   What kind of bulb is this-get-attachment-2-.jpg   What kind of bulb is this-get-attachment-1-.jpg
mbp2323 is offline   Reply With Quote
Old 08-29-2012, 03:53 PM   #2
Rewards Points: 13,458
Check in an automotive store.
If it was mine I think I would rewire it to use reguler candilarbra bulbs and do away with the transformer.
Old 08-29-2012, 04:03 PM   #3
kevinp22's Avatar
Have you tried Banana Republic?
Or A&W for a mini corn dog?
kevinp22 is offline   Reply With Quote
Old 08-29-2012, 05:45 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,184
It looks like a small neon lamp,
Probably part of a flickering candle lamp !
You should be able to get them from electronic suppliers !
dmxtothemax is offline   Reply With Quote
Old 08-29-2012, 06:08 PM   #5
Haverhill Trade 1965
Are you sure you didn't puul the glass part out of some kind of base that is still in the light socket?
Duckweather is offline   Reply With Quote
The Following 3 Users Say Thank You to Duckweather For This Useful Post:
gregzoll (08-29-2012), J. V. (08-30-2012), mpoulton (08-29-2012)
Old 08-29-2012, 06:25 PM   #6
Bill Kearney
Rewards Points: 1,174
What is that end? Some sort of coaxial sort of plug? Yeah, I'm imagine it's a neon bulb, sort of a flickering candelabra setup? Goooooooood luck ever finding a matching replacement. You'd probably be a lot better off re-wiring the fixture for bulbs you CAN find. Perhaps by replacing the whole faux candlestick portion completely.
wkearney99 is offline   Reply With Quote
Old 08-30-2012, 05:53 AM   #7
That was supposed to be pull, unless you vacuumed it out, then it has two u's.
Old 08-30-2012, 01:00 PM   #8
more pics
Thank you very much for the responses. I have definitely thought about re-wiring for regular voltage. The base screws out and looks more like a normal screw, but has a tip protruding from end. I have attached a couple more pictures that could help. Thanks again for the responses.
What kind of bulb is this-get-attachment-3-.jpg   What kind of bulb is this-get-attachment-4-.jpg   What kind of bulb is this-get-attachment-5-.jpg
Old 08-30-2012, 02:58 PM   #9
Semi-Pro Electro-Geek
Rewards Points: 2,922
That is super weird. I've never seen anything like it, and I've seen a lot of unusual lamps and electrical connectors. I would not expect to find a replacement.
mpoulton is offline   Reply With Quote
Old 08-30-2012, 03:19 PM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
I worked in a lighting store for several years before starting in this trade. In all that time I've never seen anything like that.
Old 08-30-2012, 04:33 PM   #11
If it is low voltage how do you know and how is it wired? Any idea how old it is?
Old 08-30-2012, 05:01 PM   #12
bbo
call this place, I bet they could give you an idea
http://antiquesdeprovencellc.com/xcart/home.php?cat=285
bbo is offline   Reply With Quote
Old 08-30-2012, 05:26 PM   #13
It is definately a variation of a flickering candle lamp,
I have not seen that version before,
So you might have to hunt around,
heres what i first thought it was.
Name:  flickering candle lamp.jpg
But I still think that small part,
is a neon lamp with some color on it.
If you can get the small glass envelope out,
with out breaking it, you could replace it.
Or you could just buy a new neon lamp
take it to a candle maker and get it dipped in yellow wax.
dont worry it wont melt as neons dont gererate any heat.
Remove A Broken Light Bulb Floyd Chandler Electrical 0 08-14-2011 02:50 AM
Light Bulb Burning Out GerGa Electrical 1 07-25-2011 10:20 PM
Changed Ballast only 1 bulb works nbaresejr Electrical 6 06-24-2011 07:00 PM
What kind of recessed lighting and bulb? Sardinia Electrical 2 01-28-2011 11:03 AM
Can I install a self-ballasted CFL bulb into a ballasted fixture? Daaavey Electrical 22 08-25-2010 08:52 PM
