What If? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2008, 09:54 PM   #1
When is fishing season?
CowboyAndy's Avatar
What if?
This is strictly hypothetical. I have not done this, not do I plan on it, nor do I suggest anyone else do it. I just want to know to satisfy my own curiousity.
What would happen if you tried to hook up a 240V appliance by taking 1 wire, say 4AWG, and dividing the strands in half then hooking each half to each leg of a double pole breaker, then same at recep?
Also, what would happen if you took a single pole breaker and fed it to another single pole breaker?
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-21-2008, 09:56 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
Come on Cowboy. Please tell me this is not a serious question.
Sorry, I see you edited. I am referring to the first question.
Speedy Petey is online now   Reply With Quote
Old 03-21-2008, 09:57 PM   #3
CowboyAndy's Avatar
Inquiring minds want to learn!
MY HOUSE OWNS ME!
Old 03-21-2008, 10:05 PM   #4
Think about it. After you separate the strands of the conductor, where do they go?
Old 03-21-2008, 10:06 PM   #5
Union Electrician
goose134's Avatar
Andy, I know you know the answer to #1.
As for question #2, it depends on what phases the breakers are on. If they are on the same phase, nothing will happen. It will be what we call "double fed". If different phases, see answer #1
goose134 is offline   Reply With Quote
Old 03-21-2008, 10:09 PM   #6
CowboyAndy's Avatar
To each terminal of a double pole breaker.
MY HOUSE OWNS ME!
Old 03-21-2008, 10:11 PM   #7
And then back together into the same conductor.
Dead short, no?
Old 03-21-2008, 10:15 PM   #8
Building and plumbing
USP45's Avatar
Rewards Points: 150
Dead short, no?
i am not a licensed electrician, but I did stay at a Holiday Inn last night!
Just had to say that. But seriouse, I had to get certified in trash compactor repairs in Easly SC. When we went to the class one of the subjects they tought us was to be verry carefull not to cause a phase to phase short. Mmm, I just could not imagine
USP45 is offline   Reply With Quote
Old 03-21-2008, 10:26 PM   #9
Rewards Points: 2,350
Yes those are particularly nasty, but only because of the change in voltage. Energy available in the short goes up by the SQUARE of the change in voltage. So, a 120 V line-to-ground short has X amount of explosive energy. But 240 is twice the voltage, so the available energy in a 240 V short is 4 times a 120 V short. A 480 V short has 16 times the explosive energy of a 120 V short at only 4 times the voltage. It gets bad quick.
InPhase277
Old 03-21-2008, 10:29 PM   #10
You already know what would happen. It would be the same as taking each end of the wire and attaching it to each pole of a double pole breaker.
As for the second question, current only flows when there is a difference in potential. If the breakers are on the same phase, there is no difference in potential. If on different phases...
InPhase277
Old 03-21-2008, 10:31 PM   #11
CowboyAndy's Avatar
So basiclly if they were on the same phase... nothing
if they were on different phases... sparks and noise and lots of bad stuff?
MY HOUSE OWNS ME!
Old 03-21-2008, 10:35 PM   #12
Well, maybe, maybe not. If the wire is connected to each breaker, and the breakers are connected solidly to the bus, then you just get a violent throw of the breaker handles. You may see sparks from inside the breaker. I have seen breakers shatter on high voltage systems. 480 V.
We call this "bucking phases"
InPhase277
Old 03-21-2008, 11:13 PM   #13
Yeah..............pretty much.
Ya gotta keep em separated.
220/221 is offline   Reply With Quote
Old 03-22-2008, 03:50 PM   #14
If the breakers are on different "phases", they could both trip, or one or the other might trip, leaving the other untripped. Or, both breakers could disintegrate, although I highly doubt a breaker would ever destroy itself if the voltage is with it's rating. They are designed to take huge amounts of short-circuit current.
Another thing that could happen, is there could be a very short but incredibly high surge current drawn from your local distribution system, causing a chain-reaction and finally resulting in the failure of the entire grid, leaving millions of customers without power!
I think they call that the butterfly effect.
When I was a kid, I didn't understand how the 3-way lamp switches worked. There is one position where both filaments light, thus all of the contacts of the switch are connected together.
I had this switch set up so that I could switch a lamp from getting it's power from one receptacle or another in the room.
When I switched the switch to the position where all contacts were connected, the switch blew itself up, and I blew two fuses, one on each side of the 3-wire service.
I had 240 volts across the switch, and it is almost a miracle that I wasn't shocked, or didn't start a fire!
I did a lot of really boneheaded things as a child, before understanding electricity and it's distribution.
But perhaps I knew a lot more than I thought I did, as I was rarely shocked, and never started a fire.
I did blow fuses from time to time though<g>
FW
fw2007 is offline   Reply With Quote
Old 03-22-2008, 04:49 PM   #15
USP45's Avatar
Rewards Points: 150
InPhase277
And to think, some of those trash compactors run on 660 volt. Big Boom huh?
