What The Heck Is This Device Wired To My Wall?!?! - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2013, 10:06 AM   #1
Question
What the heck is this device wired to my wall?!?!
Greetings all,
Wife and I just purchased our first home, and we found this bad boy in our master BR...
It looks like a series of switches, and the middle one says "ALL" on it.
Is this anything we need to leave intact, or can I disconnect it from the wall (after turning breaker off)?
Thanks!
drumbum811 is offline   Reply With Quote
Old 04-23-2013, 10:12 AM   #2
Rewards Points: 736
If it wasn't so old, I'd say some sort of multi-room multimedia controller.
There's no speaker nearby or I'd say an intercom.
TheBobmanNH is offline   Reply With Quote
Old 04-23-2013, 10:27 AM   #3
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Almost looks like an old low voltage control. I would expect to find a bank of relays somewhere that used to turn lights on and off. Probably in the attic or basement.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
The Following 2 Users Say Thank You to rrolleston For This Useful Post:
HIVOLT (04-23-2013), mpoulton (04-23-2013)
Old 04-23-2013, 10:32 AM   #4
You just answered a key piece of the puzzle. After some internet searching, I found this:
Remcon Nine Switch Plate
So now that I know what it is, is there harm in removing it, or should I bring in an electrician to take a look?
Old 04-23-2013, 10:55 AM   #5
Do all the lights and outlets work in the house without using this? then you can probably remove it, if not then this thing probably is still in use so removing it would require rewiring a lot of switch locations.
OCPik4chu is offline   Reply With Quote
Old 04-23-2013, 11:09 AM   #6
We haven't systematically gone through each one, but each light has worked before and after mashing each toggle switch in a variety of combinations. I have yet to see if it controlls anything outside the home (landscape lighting).
Old 04-23-2013, 11:16 AM   #7
Well thats good then, I'd still suggest looking around in the attic or basement if you have one to try and find the relay box that switch set would connect to. Bring a volt meter and you would be able to see if its still live. Easy check and if its not live or not connected you can just pull the whole thing out.
The Following User Says Thank You to OCPik4chu For This Useful Post:
drumbum811 (04-23-2013)
Old 04-24-2013, 11:40 AM   #8
Thanks, but now...
It is a switch box wired to light fixtures throughout the house. Would you all recommend bringing in an electrician to remove it, or could I cap the wires and stuff them back in the wall?
Old 04-24-2013, 01:35 PM   #9
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Low voltage lighting control. Found in older high end homes. There will be a relay in each/most/some of the lighting outlet boxes.
The relay looks like this;
It is a latching relay. Which means it has to be powered on and powered off.
SOme masters look like this;
Turn the dial to the number you want on and push it in. When you want to turn it off, turn the off dial to the number you want off and push itin. If you set the on dial to "1" and push it in theh turn the dial to "12", all the lights will turn on. SAme thing works for the off dial.
And finally, this is what the motorized master switch looks like. One for "on" and one for "off".
If the system is functional, leave it alone. To eliminate the low voltage system requires most of the lighting systen be rewired to add line voltage switches and switch legs. THe neat thing about these systems is the ability to control lighting all over the house from one location. The master consoles are usually found at the front door and the master bedroom.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
Philly Master (04-25-2013)
What the heck is this wall made of? midnightpainter Drywall & Plaster 0 08-18-2012 04:38 AM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 07:42 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
