What Is Going On In My Electrical Box? Pics - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2013, 06:05 PM   #1
Rewards Points: 35
What is going on in my electrical box? Pics
I bought a timer to control a single light on the front of my garage. The timer has 4 wires, the switch I was going to replace only had two black wires, no neutral, and wasn't grounded. I'm trying to make sense of all of the wires in this box. Can I hook it up with the wires that are in there? Sorry if this is confusing, but I'm hoping something in the box is a neutral wire. (the house is old, 1960's)
Here are the pics I took. Any thoughts? Is this dangerous the way it is wired now? Any hope I can hook up my new timer?
d189379 is offline   Reply With Quote
Old 03-08-2013, 06:08 PM   #2
Electrician
Rewards Points: 760
Use the neutral that is on the plug for your timer.
darren is offline   Reply With Quote
Old 03-08-2013, 06:12 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 144
I don't know what timer you bought, but if it requires a neutral, then you can tap it from the receptacle.
The black wire under the wire nut is the feed to the switch, and the other black on the switch goes to the light.
I would pigtail the neutrals.
The Following User Says Thank You to jbfan For This Useful Post:
d189379 (03-08-2013)
Old 03-08-2013, 07:36 PM   #4
kbsparky's Avatar
Since your box is grounded, mounting the timer into the metal box should take care of the ground. But you can pigtail the bare wires with the green one if you really want to.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Old 03-08-2013, 07:46 PM   #5
Rewards Points: 35
Sorry, I guess what I was asking was if there is in fact a neutral wire in the box, and if there is, how do I figure out which one it is?
The timer says I need a neutral, ground, line, and load connection.
I'll ground the green wire to the box, line and load are there, it's just the neutral I can't figure out. Is it one of the white wires attached to the recepticle? Can I just piggyback off of one of those?
Old 03-08-2013, 07:46 PM   #6
Rewards Points: 35
Yeah, I was just going to ground to the screw in the back of the box.
Old 03-08-2013, 08:11 PM   #7
Electrician
Rewards Points: 760
There both a neutral, you have your incoming power and then the power leaves the box.
Take the two white off the the plug make a joint with those two whites, another 6 inch white and the white of the timer. The 6 inch white would go to the plug.
The Following User Says Thank You to darren For This Useful Post:
Old 03-08-2013, 08:12 PM   #8
Electrical Enthusiast
Rewards Points: 504
For the neutral, you'll need to take the two neutral wires off the receptacle, wire-nut them together, making a pigtail with a new wire to one of the receptacle screws, and the wire from your timer switch.
Kyle_in_rure is offline   Reply With Quote
The Following User Says Thank You to Kyle_in_rure For This Useful Post:
Old 03-08-2013, 10:15 PM   #9
Rewards Points: 35
Thanks a lot. You guys are awesome.
Demo'd Half-Bath, Pics Attached, Any Electrical? 99altrade Electrical 7 12-22-2010 03:48 PM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 03:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
