-   -   What is going on in my electrical box? Pics (http://www.diychatroom.com/f18/what-going-my-electrical-box-pics-173944/)
d189379 03-08-2013 06:05 PM
I bought a timer to control a single light on the front of my garage. The timer has 4 wires, the switch I was going to replace only had two black wires, no neutral, and wasn't grounded. I'm trying to make sense of all of the wires in this box. Can I hook it up with the wires that are in there? Sorry if this is confusing, but I'm hoping something in the box is a neutral wire. (the house is old, 1960's)
Here are the pics I took. Any thoughts? Is this dangerous the way it is wired now? Any hope I can hook up my new timer?
http://i147.photobucket.com/albums/r...54_resized.jpg
http://i147.photobucket.com/albums/r...43_resized.jpg
http://i147.photobucket.com/albums/r...9_resized1.jpg
darren 03-08-2013 06:08 PM
Use the neutral that is on the plug for your timer.
jbfan 03-08-2013 06:12 PM
I don't know what timer you bought, but if it requires a neutral, then you can tap it from the receptacle.
The black wire under the wire nut is the feed to the switch, and the other black on the switch goes to the light.
I would pigtail the neutrals.
kbsparky 03-08-2013 07:36 PM
Since your box is grounded, mounting the timer into the metal box should take care of the ground. But you can pigtail the bare wires with the green one if you really want to.
d189379 03-08-2013 07:46 PM
Sorry, I guess what I was asking was if there is in fact a neutral wire in the box, and if there is, how do I figure out which one it is?
The timer says I need a neutral, ground, line, and load connection.
I'll ground the green wire to the box, line and load are there, it's just the neutral I can't figure out. Is it one of the white wires attached to the recepticle? Can I just piggyback off of one of those?
Yeah, I was just going to ground to the screw in the back of the box.
darren 03-08-2013 08:11 PM
There both a neutral, you have your incoming power and then the power leaves the box.
Take the two white off the the plug make a joint with those two whites, another 6 inch white and the white of the timer. The 6 inch white would go to the plug.
Kyle_in_rure 03-08-2013 08:12 PM
For the neutral, you'll need to take the two neutral wires off the receptacle, wire-nut them together, making a pigtail with a new wire to one of the receptacle screws, and the wire from your timer switch.
d189379 03-08-2013 10:15 PM
Thanks a lot. You guys are awesome. :thumbup:
