What Gauge Wire For 100 Ft Run? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-19-2011, 03:30 PM   #1
What gauge wire for 100 ft run?
My electrician was supposed to run an electrical supply line to the side of a pond but he has not showed up. My landscaper is installing sod on Thursday morning so he has to dig the trench and I have to put in the pipe and wire and then find an electrician.
I have a dry pond with two waterfalls each using a 1000 W pump. The run (in the ground) from the back of my house to the pond is approximately 35 ft. The distance (in the basement) from the front of the house to the back of the house is 43 ft for a total of approximately 80 ft. I have two waterfall pumps which are 1000 W each.
I would greatly appreciate it if someone can tell me the following:
1) what gauge wire to use and should I use one larger gauge wire or two smaller gauge wires
2) how deep does the pipe have to be buried
Thanks!
philesq is offline   Reply With Quote
Old 07-19-2011, 03:39 PM   #2
Licensed Pro
Don't worry about the wire yet, just bury 3/4" PVC a minimum of 18" deep. Make sure you glue all connections well and don't use more than four 90 deg elbows.
Old 07-19-2011, 03:44 PM   #3
Thanks!!!
Old 07-19-2011, 04:27 PM   #4
Rewards Points: 1,016
12" bury depth if a single 120v circuit protected upstream by GFCI in the house.
____________
Vince
Old 07-19-2011, 07:04 PM   #5
Rewards Points: 6,652
For that length, if just 110, I would go with #10.
Old 07-19-2011, 07:18 PM   #6
Just call me Andrew
Rewards Points: 1,020
Run a string through the conduit, tie/tape the wire to the string to make it easier to pull. MIght want to run a couple in case one breaks.
Andrew
secutanudu is offline   Reply With Quote
Old 07-19-2011, 10:50 PM   #7
" Euro " electrician
frenchelectrican's Avatar
Just run 3/4 inch PVC conduit buried at 18 inch deep then will deal with circuit set up due the 3/4 conduit can handle 2 or 3 circuits without issue.
For the waterfall pumps you can have a choice .,,
Timer for both or indivual pumps or manual control aka switch.
Have a extra circuit for luminaires I am pretty sure you will need it one way or other.
Merci,
Marc
What size ground wire should I use for 8 gauge power dxmullin Electrical 1 07-06-2011 02:57 PM
wire gauge rob waas Electrical 1 07-02-2011 08:47 PM
Hot Water Heater Wire Gauge bphilip Electrical 16 09-18-2010 07:23 PM
20A Breaker, 14 gauge wire? joside Electrical 12 08-25-2010 09:41 AM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
