What Gage Wire Do I Need - Electrical - DIY Chatroom Home Improvement Forum
Old 09-30-2011, 11:09 PM   #1
what gage wire do i need
im runing a 240 v.a.c. 4000/2700 watts 16.7/11.1 amps space heater what gage wire do i need to run 40 ft. spand
jarodseifert is offline   Reply With Quote
Old 10-01-2011, 03:29 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Spand??
All the wiring will be inside or will be exposed to outdoor or running this in the conduit { pipe } ??
and for your heater you will need #10 awg size but before we can go more answer that simple question above then we can go from there.
And do you have room in your breaker box for it ?
Merci.
Marc
Old 10-01-2011, 12:14 PM   #3
it will be inside run across the grarge to the room
it will be inside
Originally Posted by frenchelectrican View Post
Spand?? ge
Merci.
Marc
Old 10-01-2011, 12:25 PM   #4
Licensed electrician
Rewards Points: 1,240
I think they meant the run or span would be 40 feet.
Old 10-01-2011, 05:52 PM   #5
i will be runing it up throw the adeck thin down into the room
it will be inside
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 07:41 PM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Wire Gage for the Sub-Pannel jamiedolan Electrical 11 09-09-2008 12:33 PM
