What To Expect The Inspector To Require? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-11-2009, 08:53 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
What to expect the Inspector to require?
HI
For those of your that are following the thread "Unfused connectors MELTED house wires" you already know what is going on. To summarize, due to the heat damage, virtually all of the cables going into my dads panel are going to have to be replaced or junctioned back a few feet before the panel and re-fed to the panel.
80% of these circuits are old ungrounded circuits. Are they likely to consider this junction as a modification to the circuit and require the circuits be brought up to current code (i.e. rewired with a ground)?
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 01-11-2009, 08:59 PM   #2
Hard to say, he might want to take a look at the panel, and where the junction is going to be placed.
He might get the wrong idea about the incident and may think all of the wiring is burnt.
rgsgww is offline   Reply With Quote
Old 01-11-2009, 09:08 PM   #3
DIY'er
jamiedolan's Avatar
If that is the case, I sure hope the insurance will cover what is required. His policy is suppose to cover up to 240,000 for this type of event. We will see what they say tomorrow.
In all honesty, it would be a good thing to get much of his old wiring replaced, just going to be very extensive and expensive.
Jamie
Old 01-11-2009, 10:14 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by jamiedolan View Post
HI
Jamie
unless you have one of the good ol' boys as an inspector,I would almost be willing to bet your dad will have an EGC accompanying all circuits in the house.
Old 01-12-2009, 11:45 AM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by nap View Post
.........your dad will have an EGC accompanying all circuits in the house.
For those who don't know, EGC is:
Equipment Grounding Conductor
Disclaimer
& Stay Safe
.....Bob Lavery
Old 01-12-2009, 11:58 AM   #6
Take plenty of pictures of everything as well as your electrical service wires/mast, grounding, inside electrical panels/wiring.
Then go to your electrical inspectors office and ask what will be required. In my area they have certain hours where you can go and ask questions. But better if you take pictures so they can see what is currently there.
If you need to bring your electrical service up to code, this might require changes to pipes or runs of the wires coming from the electric company as well as grounding. So take pictures of all that stuff as well.
Also take a far away pictures of the panel area and wires entering your house. There are requirements for things next to an electric panel and wires running over the tops of roofs.
Billy_Bob is offline   Reply With Quote
Old 01-12-2009, 01:40 PM   #7
The panel might need to be replaced...means a replacement of the old se.
How many coats of prime require on new drywall? KUIPORNG Painting 23 02-26-2011 07:47 AM
Does your job require a permit? housedocs General DIY Discussions 203 12-01-2010 08:28 AM
Exterior Wall Insulation require plastic barrier? BillyDIY Building & Construction 14 03-05-2009 11:19 AM
does a switch in an old work box require a ground? jheavner Electrical 7 10-05-2008 12:09 AM
Wood floor refinish cost - what to expect? Ducowti Flooring 7 04-13-2005 08:44 PM
