What Is This Electrical Box For? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-26-2011, 12:14 AM   #1
What is this electrical box for?
I uncovered the plate in my bathroom to paint the walls and I am curious to what this is for.
I have one outlet on the opposite wall. This box is right above the light switch on the other side of the wall. I'm not sure but the wires don't seem to look like the wires in the other outlet. Could it be for another outlet?
I hope I don't sound too stupid.
AirheadAnnie is offline   Reply With Quote
Old 05-26-2011, 12:45 AM   #2
Rewards Points: 512
It may at one time have been a light fixture (depending on the height), or a receptacle that was removed. Unless there's a problem, it shouldn't be of any concern. The cover should be blank, with no opening.
Old 05-26-2011, 05:42 AM   #3
Licensed electrician
Rewards Points: 1,600
Whatever it was the box was overfilled.
Old 05-26-2011, 08:19 AM   #4
I ask the impossible!
Rewards Points: 692
It's like Mad Max Beyond Thunderdome in reverse... 1 goes in, 2 come out.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 05-26-2011, 01:26 PM   #5
Rewards Points: 512
Interesting. What would be the fix here, as far as removing it without damaging the hole too much to use a retrofit box?
Old 05-26-2011, 03:37 PM   #6
What do you mean by overfilled?
I thought if the wiring was correct for another outlet, I would put one in.
Old 05-26-2011, 03:40 PM   #7
Learning by Doing
Leah Frances's Avatar
He means both that it's 'overfilled' and that there's no way on earth you could wedge an outlet in there.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-26-2011, 05:32 PM   #8
Rewards Points: 512
The box is not deep enough for the amount of wires in it. It is called "Box Fill" and is covered by Code.
If you wanted to put in a receptacle, you'd have to pull that box out, and get a deeper box to put in.
Old 05-26-2011, 05:35 PM   #9
Scared Electrician
Saturday Cowboy's Avatar
there are rules ad to how many wires you can cram in a certain size box, etc.
the solution (should you choose not to just ignore it) would be to install a extension ring, it would stick out a way from the wall a bit.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-26-2011, 05:43 PM   #10
Rewards Points: 512
If those wires are #12, is my calculation correct yielding 18 cu. in.? I did not include the wire nuts; is that an error?
Old 05-26-2011, 05:43 PM   #11
Rewards Points: 6,652
I am going to take a stab, the box & wall appears to be the same age that is in my house (pre-1940's). The box in the bathroom before we renovated had three armored cable in it, and same with the back bedroom & living room. I would say time to either pull out the one wire after finding out where it goes, or get a bigger box.
Old 05-26-2011, 06:13 PM   #12
Scared Electrician
no you don't count wire nuts, in the US(yes in CANADA)
I'll bet the wire is 14ga TW wire
The Following User Says Thank You to Saturday Cowboy For This Useful Post:
sirsparksalot (05-26-2011)
Old 05-26-2011, 06:25 PM   #13
Rewards Points: 512
I can't bet against you; you get to look at it more than I Is TW wire insultaion bigger than it's Romex cousin?
Old 05-26-2011, 07:00 PM   #14
Scared Electrician
been playing with it a lot on the current job IRL. TW is thicker than THHN by almost 2x, It is a much older insulation type, not seen to much in new work.
Old 05-26-2011, 08:17 PM   #15
That box volume might be as low as 7.5 cubic inches. Each #14 requires 2 cubic inches. Currently there are 6 conductors in that box for a minimum capacity of 12 ci. Add a device and the box would need to be 16 ci minimum.
Last edited by Jim Port; 05-27-2011 at 07:37 AM. Reason: corrected conductor count
Old Bathroom - all electrical on one circuit? how to change? Steve19 Electrical 16 03-14-2011 09:32 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 08:15 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
