What Does X And Y Mean? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-12-2009, 07:31 PM   #16
Mike, the clothes go stiff because the heat in the room air being sucked into the dryer is being used to run a generator. Wiring it backwards generates electricity. In some jurisdictions one can receive heavy fines or even jail time for generating electricity without a license/permit, in addition to the required business licenses & permits. (licenses for generators and licenses for distribution)
The advantage and disadvantage of using a natural gas dryer is that this cannot happen; they only work one way.
99BN99 is offline   Reply With Quote
Old 07-12-2009, 07:37 PM   #17
Originally Posted by Mike in Arkansas View Post
It's imperative that the two hot wires be connected to the proper x and y terminal. If they are connected incorrectly, the dryer will work in reverse and blow cold air instead of hot. If you find your clothes frozen stiff as a board reverse the two wires. That is why virtually all freezers and refrigerators are 115 volts. Only one way to wire them up. Otherwise half the people would wire them backwards and cook the stored food rather than preserve it. No need to thank me for providing this information. I've learned so much from others here on this forum I'm just happy to be able to return the favor.
Is that the same way heat pumps work?
jerryh3 is offline   Reply With Quote
Old 07-12-2009, 09:08 PM   #18
You certainly didn't learn that on this forum...well, you didn't learn it from those who know electricity, anyway...
...uh, ... yeah... well, hopefully the OP can tell the correct answer from the BS
Willis
williswires is offline   Reply With Quote
Old 07-12-2009, 10:13 PM   #19
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
Willis, if the OP cannot tell the joking from the real answers in this thread then they should not be touching electrical.
Speedy Petey is online now   Reply With Quote
Old 07-12-2009, 11:24 PM   #20
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 70
Oh shoot, I was about to patent an all purpose freeze/cook device by modifying a fridge to use a toggle switch and reverse the hot and neutral! You just bursted my bubble! :p
But yeah, knew it was a joke, reversing AC does not really do much. It changes 60 times a second anyway. Just need to get neutral and hot correctly as it's hooked up a certain way at the panel and hot is what is "cut" when a switch or breaker is thrown, so you don't want neutral having any power to it on it's own.
Old 07-13-2009, 03:25 AM   #21
" Euro " electrician
frenchelectrican's Avatar
Speaking of X , Y , Z for the European verison it will be R S T it the same thing so in case you see it it will line up the same pattern as X Y Z is
Merci,Marc
