What Does The Date Printed On Romex Wires Mean? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2010, 04:54 AM   #1
What does the date printed on romex wires mean?
Is it the date they were manufactured?
leebirnbaum is offline   Reply With Quote
Old 10-23-2010, 06:06 AM   #2
Electrician
Rewards Points: 794
No thats the expiry date, if has not been installed by that date you have to throw it out and buy new stuff, same idea as a jug of milk.
darren is offline   Reply With Quote
Old 10-23-2010, 07:48 AM   #3
the Musigician
DangerMouse's Avatar
Like my Grandpappy used to say: Always better to be a smart@$$ than a dumb@$$......
DM
Old 10-23-2010, 08:08 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
Don't ya hate it when the electrons leak out, it loses all it's fizz, and starts to smell funky??
Kyle
Old 10-23-2010, 08:32 AM   #5
the Musigician
Yup, and it's next to impossible to scrub those damn electrons out of the carpet......
DM
Old 10-23-2010, 10:01 AM   #6
Electrician
Rewards Points: 794
Just like when the smoke escapes from electronic devices, you can spend hours putting the smoke back in but it still never works the same.
By the way the date is probably the manufactuering date.
Old 10-23-2010, 10:31 AM   #7
Rewards Points: 160
It's called the "date code" same as the serial number for tracking and recalls if required.
The Following User Says Thank You to J. V. For This Useful Post:
DangerMouse (10-23-2010)
Old 10-23-2010, 12:07 PM   #8
Thanks guys.
And per the analogy, yes, something definitely "stinks" up in the attic with respect to the wiring.
THe reason I asked about the date code is because I'm trying to figure out when certain work was done.
I just bought a duplex and like many foreclosed properties, the electrical is a mess. A hodgepodge of very old original wiring combined with updates through the years, and then new work from the previous owner that tried to remodel and then ran out of money and was foreclosed upon.
Before attempting to debug any of the mess, the 1st thing I had done was have the 2 panels updated from the faulty Federal ones in the closet to up to date ones out of the closet.
Now the real fun begins.
However, I'm seeing a lot of improper work that I suspect may be the result of the electrician I had update the panels cutting corners.
For example, I'm seeing older 10 gauge wires junctioned to newer 12 guage wires and then routed to the panel on a 20A breaker.
While this is OK safety wise, it means the circuit no longer supports 30A, and I'm trying to figure out if it already was that way, or if my electrician saved a few bucks by using higher guage wire.
Since I didn't examine any of the wiring prior to having the panel changed, I have no real way to tell, other than the fact that there's a date code on the romex.
So, if the date is as Darren 1st suggested, an expiry date, then there is no evidence that these wires were installed by my electrician.
But if the date is a manufacturing date, then that says it all because the date is from around May 2010, and the property has been in foreclosure for
over 6 months.
So the only work performed since Hune was my guy, and thus, the gunis smoking.
THere are other issues with stuff I had him do that doesn't meet code and am going ot have ripped out (for example, he installed a 220V dryer line for me using 3 wire (White/Black and Ground) with no neutral (for 4 prong), or at the very least, a neutral instead of ground for 3 prong.
Obviously, he thought he could save money on the wire and that no one would inspect, and he lost his poker hand. I'm just deciding if a) just don't pay for faulty work, or b) pursue with the board of licensing.
None the less, none of that's important now, I just mention to give more perspective.
All I care about at this instant is knowing exactly what the wire date means so that I can do my own "forensics" in tracking exactly what he did vs. what other incompetent people did before I bought the property.
Thanks again guys...
-Lee
Old 10-23-2010, 12:13 PM   #9
About the "uses" of the manufacturing code...
I wonder if unusually thorough building code inspectors might look at the wire date codes and then see who owned the property when the work was done, and if recent work, might use that as legal recourse to go after licenses (or lack of) to pursue things like lack of permit or improper work and who did it.
If so, it almost seems like there might be a commodity market for "older" wire with an older date code for use by "joe handyman" that does electrical work with out a license and doesn't want it tracked to him. lol
--Just liek unlicensed AC people that buy freon on the "black market".
It would be funny (well not really) if 3 year old wire is being sold on ebay for 3X the original cost. haha
Old 10-24-2010, 03:29 AM   #10
Just an update you guys might find "interesting".
Last, I mentioned the incorrect 2-wire WG dryer circuit he wired.
Today, I went up to the attic and pulled it out since it needs to be 3 WG.
In doing so, I found that he had spliced it together int he attic with out a junction box, and hidden wedged under the floor boards stuffed between very dry old wood.
THis is a pretty severe code violation, isn't it?
Not only is is the splice done w/out a protective junction box, but it's totally hidden and worse, hidden wedged in dry flamable wood.
THis electrician I realized is only a Journeyman.
I think it's time for a master since at this point, I'de be better off doign the work myself...
THanks for the ear...
-Lee
Old 10-24-2010, 08:43 AM   #11
I bought quite a few rolls of wire a few years ago
It was when 12-2 was $29 a roll
I used that stuff for years
Quite the price shock when I went back & saw the price was @$99
I bought 3 rolls back in 08 when I started my addition
Just using the last of it up now
I've never had my Inspector look at any date codes
I've heard - urban legend ? - that insurance companies may check date codes to see when work was completed if damage/fire was caused by electric work
Old 10-24-2010, 09:06 AM   #12
Electrical Contractor
kbsparky's Avatar
BEWARE of installations that have 12-2 spliced to "older" 10-2 wires. Those 10-2 wires may be aluminum ... I'd check that aspect out!
-KB
Old 10-24-2010, 09:22 AM   #13
over 6 months.
-Lee
There is no such thing as an expiration date on wire
That was meant as a joke..........
Old 10-24-2010, 11:07 AM   #14
Fortunately, no aluminum wiring.
When I see that, I just have it all updated (or even better, stay away from buying the property).
Old 10-24-2010, 11:09 AM   #15
I figured as much.
I would think the outside plastic wrap would deteriate (and thus the date not be ledgable) long before the copper or insulation on the wire...
Meaning, that if you can't read the date, it's "expired".
Kind of like the bumper stickers that say, "If you can read this, you're too close". (only the opposite in analogy).
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 09:08 AM
two romex wires in 3/4" conduit ugabulldog Electrical 12 05-24-2010 01:40 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
Running new doorbell wires after ripped old ones out? pcampbell Electrical 3 12-14-2008 11:31 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
