#1 |
What does this breaker go to?
SO I have pretty much tested all the outlets and electrical switches and lights in my entire house. Any shot anyone here would have a suggestion as to how I can figure out what the heck the 4th and 2nd breaker from the bottom right supplies power to? The 4th from the bottom is a 15a and is the ONLY 15a in the panel. The others are all 20a.
I suppose it could be to nowhere. But it's driving me mad! |
#2 |
#3 |
Turn it off, leave it off until something doesnt work.
#4 |
Impossible for anyone here to know where it goes. As suggested just leave it off and see what does not work.
#5 |
Average Joe/ex-Navy IC3
I was wondering why my Kitchen lights kept going off. Stop playing with that breaker.
If none are labeled, plug in a radio, flip breaker, radio off, label breaker for that room. Same thing with lights. I am sure you will figure it out.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#6 |
I would use my telephone toner.
| The Following User Says Thank You to bobelectric For This Useful Post: | Missouri Bound (11-19-2012) |
#7 |
Agreed..just turn that one breaker off, then see what doesn't turn on. Hopefully its not an open line in your attic or under your house if u have suitable crawl space/attic. I've seen that plenty of times. If possible u can also ohm it out..if you know how?!
#8 |
Electrical Contractor
Lift pump and alarm out in the yard ....
-KB Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#9 | |
What does this breaker go to?Quote:
#10 |
Open line(open hot, power is live). Ohm: conducting a test on your digital ampre meter, first shouting the power off, seeing where the line takes you by ohming it out starting from the service panel, circuit where the breaker is on.
#11 |
As a experienced electrician its nothing difficult about it, just knowing what your doing is the main factor.
| The Following User Says Thank You to JuzRick For This Useful Post: | gregzoll (11-20-2012) |
#12 | |
#13 | |
To perform a resistance test, turn the breaker off, plug your meter leads into the appropriate sockets on the meter, set the meter switch to read resistance, connect the end of one meter lead to one end of the circuit and the other lead to the other end of the circuit (wire). Does the meter read 0 ohms (or close to it) or a very large resistance. |
| Display Modes | |
| Separate 110 and 220 receptacles on 2-pole 220 V Square D GFI breaker | sunrise | Electrical | 1 | 05-13-2012 08:27 PM |
| Well pump trips breaker at start, but then starts when breaker reset | J. David | Electrical | 34 | 02-25-2012 12:23 PM |
| Outside breaker, inside main breaker panel, so is it a sub? | CPF | Electrical | 29 | 02-01-2012 11:28 AM |
| Wiring Size Calculations for New Service | CorinthWest | Electrical | 7 | 12-07-2010 12:36 PM |
| Outdoor breaker panel questions | lhoney2 | Electrical | 12 | 07-19-2007 06:44 PM |
