What Does 30A/16A Mean - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2011, 12:21 PM   #1
What does 30A/16A Mean
Ok, so I know I need to run a 10gauge wire for a 30amp outlet but out of curiosity what does 30A/16A mean?
Thank You
kenh426 is offline   Reply With Quote
Old 07-06-2011, 12:44 PM   #2
Master Electrician
Rewards Points: 3,960
What type of receptacle and where is the label located that you are talking about?
brric is offline   Reply With Quote
Old 07-06-2011, 01:03 PM   #3
http://www.aquapeutics.com/mido/Stea...Florenceb.html
This page shows the diagram.
Old 07-06-2011, 01:13 PM   #4
Master Electrician
Without more extensive info my guess is that you need a 240 volt feed and a 120 volt feed.
Note the recommendation for a professional plumber and/or electrician.
Old 07-06-2011, 03:17 PM   #5
Rewards Points: 1,016
Or help via a great DIY site.
____________
Vince
Old 07-06-2011, 03:30 PM   #6
I see your confusion. I think they are asking for two circuits - 240v for the optional heater, and 120v for lights and such. However, I am not sure. I did not see where one could download or view the actual installation instructions. If not available online, suggest you contact the vendor directly and ask for clarifiction.
____________
Vince
Old 07-06-2011, 03:32 PM   #7
Missouri Bound's Avatar
The dual amperage requirements is a bit confusing. Usually it refers to either 120 or 240 volt sources, but it really doesn't indicate that in the drawing or the specs. I'd expect one to be 120 and the other 240. Do what a "professional" (or master) would do and call the mfg. and ask. It doesn't ever hurt to ask the questions, regardless of your expertise. I've seen experts burn up so many things because they "thought" they knew.
Old 07-06-2011, 03:33 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,990
The specifications seem to say that it requires 11.8A at 120V, and also 13.6A at 240V. So you need two dedicated circuits for this thing. The NEC would allow the 120V circuit to be a 15A, and the 240V to be 20A. I can't tell for sure from the diagram, but chances are you'll need to install these receptacles inside the wall (mounted sideways on a stud), and have an access panel on the other side, since this shower does not appear to be a removable appliance.
mpoulton is offline   Reply With Quote
