What Do You Use To Reconnect A Large Gauge Wire That Was Cut? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-07-2007, 10:09 PM   #1
What do you use to reconnect a large gauge wire that was cut?
I have a large wire that I need to repair. It was cut. It is about the thickness of an index finger. What is the best way to repair something like this? I have seen them crimp these things on my power lines when they broke. But, I don't know what those are called. I saw those things at Lowes that you stick the wires in and you turn a nut...but I dont know how good those are. Any ideas? Can you give me a specfic name? Thanks!
bonedoc is offline   Reply With Quote
Old 08-08-2007, 07:34 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 232
Can you tell us what the wire feeds, and where it is cut?
Any repaires will have to be inside a box, and remain assessible.
somewhere on the wire will tell the size.
Old 08-08-2007, 09:19 AM   #3
I cannot see anything on the exposed section that says the size. It is almost 1/2" thick. It is in the ground, and I already put a box around it. I just dont know how I should connect them. A crimp sort of fitting looks like it would be nice, but I dont know what those are called.
Old 08-08-2007, 10:55 AM   #4
I would use copper split bolt lugs inside a weather proof box. Make sure you wrap the lugs/exposed wires with at least 10 wraps of high quality electrical tape (Scotch 33+ or better).
martyshel is offline   Reply With Quote
Old 08-08-2007, 11:23 AM   #5
That sounds great. I have one question about those pieces. The ones that I have are U shaped and there is a bolt that screws down on it. Do I place the wires on top of each other and then tighten in down, or do I touch them end to end and then tighten them down? It does not seem like the end to end deal would be very easy to do. Will this fitting reduce the amount of electrical flow , or does it even matter because the rest of the wire is huge?
Old 08-08-2007, 07:54 PM   #6
joed's Avatar
Rewards Points: 11,998
Place them on top of each other from opposite directions.
Old 08-08-2007, 08:56 PM   #7
Master Electrician
JohnJ0906's Avatar
What is this wire?
Where does it go?
Is there any voltage??
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 08-10-2007, 07:02 PM   #8
Custom Cabinet Maker
BONEDOC!!!!!!!!!!!!!!!!!!! Please explain GOES IN THE GROUND????????
Is this a bare wire? Does it connect to a big rod about 1/2 or 5/8" in dia that sticks up a bit?? Sounds like the earth ground for your electrical service!!!
This is nothing personal but I think you should stop where you are and get an electrician. presuming this is the ground God forbid any kind of short anywhere in your system as u are messing with this and YOU become the path to ground. TOAST comes to mind. Be Safe Call
JackM
skymaster is offline   Reply With Quote
Old 08-10-2007, 08:00 PM   #9
Agent 000
SecretSquirrel's Avatar
BoneDoc can validate this or not... but I believe all this may have originated from this thread. Take a peak and maybe it'll shed some light on the issue.
SecretSquirrel is offline   Reply With Quote
Old 08-10-2007, 10:52 PM   #10
Mike answered your PM. my public answer to this additional information
He is scaring me I am not an electrician but have been in construction over 25 yrs I feel safe to say No Way Jose.
JackM
10 gauge vs 12 gauge wire for 30 amp line hsdude1992 Electrical 10 08-19-2015 02:43 PM
going from 220 large wire to 220 small? bonedoc Electrical 7 08-06-2007 11:17 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
ok to leave chandelier third wire unconnected? gonzales9 Electrical 5 01-12-2006 09:10 PM
Does a 6 x 12ga wire nut exist? peeks Electrical 1 10-02-2005 10:58 AM
