Old 11-30-2008, 12:27 AM   #1
What do you think of coaxial terminators and isolators?
Do you ever use them? I just installed them and I got rid of that 60hz interference. A lot of installers forget the terminators.
rgsgww is offline   Reply With Quote
Old 11-30-2008, 07:24 AM   #2
I think a lot of the newer splitters/connections are self terminating. But, it wouldn't hurt to use the terminators if you want to.
jerryh3 is offline   Reply With Quote
Old 11-30-2008, 12:04 PM   #3
J. V.'s Avatar
What are terminators?
Old 11-30-2008, 12:06 PM   #4
http://www.allentelproducts.com/cata...odel_CT59T.htm
Old 11-30-2008, 01:12 PM   #5
Electrical Contractor
kbsparky's Avatar
This:
Old 11-30-2008, 01:49 PM   #6
It was a dark and stormy
Yoyizit's Avatar
Terminators are used to prevent signal reflections within the cable when it's not terminated in its characteristic impedance (in this case, 75Ω).
Old 11-30-2008, 02:49 PM   #7
DIYer
You usually only need terminators if you have a stub. This can happen if you use T-connectors or have splitters with unused cables attached to them. Professional video equipment can go Hi-impedance but most home stuff assumes it's also terminating the bus.
Gigs is offline   Reply With Quote
