What Do You Sparkies Do About Ac Disconnects And Romex Connectors? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-15-2009, 09:32 PM   #16
Originally Posted by 220/221 View Post
I use snap ins.... but the black buttons, being connectors, keep it legal.
Im going to try and pick up some of those sometime. Its been cold and warm around here, so its hard to find time to fix the issues.
Now I'm thinking a new well install needs to be fixed up...
rgsgww is offline   Reply With Quote
Old 03-15-2009, 09:56 PM   #17
Electrical Contractor
kbsparky's Avatar
Originally Posted by rgsgww View Post
Sounds like a good idea, but, nap said that I cannot use nm-b outside, I know that, but can't I run it from inside the house to the disco?
As long as you enter the disco thru the wall and directly into the back of the enclosure, the NM isn't considered to be "outside" per se, since it isn't really exposed to the elements.
Old 03-15-2009, 10:13 PM   #18
That is what I thought originally, but I had to double check.
Old 03-17-2009, 11:28 PM   #19
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
maybe I misread but I thought you said it came in to the bottom of the disco. That would mean it was exposed.
If it comes in to the back, then you can generally get away with NM.
Old 03-18-2009, 08:05 AM   #20
It is going into the bottom for two other discos, so I'm going to fix that problem by entering through the back. I also need to get thwn and put it through the liquid tight. The "electricians" used romex through the liquid tight and were the ones who put it through the bottom of the disco.
