Old 04-04-2011, 04:49 PM   #1
What do you recommend? Broken wire!
Made an oops on the weekend.
1) I drilled through the ground and neutral on 14/2 wire...black hot is perfect. This line comes directly from the panel to an outlet and is in the floor joists. I just had enough to connect the neutral and ground with a merrett (sp?).
I know it is best to replace the entire run - but i would have to tear apart the drywall on the entire wall to rerun this line.
Is it ok to cut the line, put 2 electrical boxes in, with a 14/2 running from one to the other? This area will be exposed through drop ceiling.
2) Also on another joist i just slightly nicked the outside coating of a neutral wire, less than 1mm nick...Am I able to just tape this up with electrical tape?
I live in Canada as code may vary.
Thanks!
hellothere123 is offline   Reply With Quote
Old 04-04-2011, 05:16 PM   #2
Learning by Doing
Leah Frances's Avatar
Thanks!
Good job to give us your location. I'm only familiar with NEC so I'll keep my mouth shut. Hard lesson for knowing where your lines are before you drill. Sorry.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-04-2011, 05:16 PM   #3
old guy contractor
tcleve4911's Avatar
I think the 2 boxes work if they are accessible through the dropped ceiling.
The nicked wire ....tear out the other half of the house....
They'll be along shortly to quote the National Electric code book for ya.....
tcleve4911 is offline   Reply With Quote
Old 04-04-2011, 05:20 PM   #4
You can put in two electrical boxes and run a line between them as long as they are accessible. You can use 14/2 if that is what you have there now.
teamo is offline   Reply With Quote
Old 04-04-2011, 05:21 PM   #5
Learning by Doing
Originally Posted by tcleve4911 View Post
The Sparkies are gonna chime in on this one......
They'll want you to rip the whole house apart...
Cleve - you're right about both things - And it is a good thing that someone does tell us what we're supposed to do.
Old 04-04-2011, 07:48 PM   #6
Wire Chewer
Red Squirrel's Avatar
Yep I'd just go with two boxes. Sure beats rerunning otherwise perfectly good wire. you are adding more potential failure points, but when's the last time a marette let go on you? As long as they are accessible you are good to go. I always like placing a box assuming I will need to go back to it at some point. While the odds of a wire letting go is quite slim if it's done right, it can happen, or you may potentially want to tap into it at some point depending on what the circuit is for.
Old 04-04-2011, 08:01 PM   #7
ThaNKS for the info:
I'll just tape up the neutral that I nicked.
And I'll try to get enough slack to put the broken neutral and ground into one box...if not, then I'll put in the 2 boxes and jumper them across.
We'd all like to be Mike Holmes and remove everything if we see a screw in the wrong spot - but things gotta get done - as long as they are safe.
And I'll take a bit more time before I drill...just a few seconds here and there actually saves time - imagine that!
Old 04-05-2011, 11:51 AM   #8
J. V.'s Avatar
And what do you recommend we use instead of the NEC?
Old 04-05-2011, 09:32 PM   #9
old guy contractor
tcleve4911's Avatar
Hey JV
Sorry if my bad joke offended you.
It was not a slam at NEC or you or anybody.
I will be more mindful of what I post in the future.
Tom
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-15-2009 12:17 AM
broken electric feed wire waverly guy Electrical 9 06-08-2009 05:35 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
